Suspension & Brakes Theory, alignment, spring rates....
Tein basic damper top nut
Old Jul 19, 2010 | 05:07 PM
Doom325's Avatar
Default Tein basic damper top nut
What do you guys use to keep the shaft from spinning when tightening this nut? Something along the lines of pliers with a rubber mouth?
Old Jul 19, 2010 | 05:41 PM
Drive 4 fun's Avatar
Default Re: Tein basic damper top nut
I am not sure about the basics, but SS have a top on shaft with flats that you wrench. Most shafts are fairly hardened if you have to grasp, and you can do that above the damper travel.
Old Jul 19, 2010 | 05:51 PM
Doom325's Avatar
There are flats on the shaft but I just dont want to mangle any of the threads for the nut. With my previous set of kyb agx struts I mangled them quite a bit. I probably just need to be a bit more careful
Old Jul 19, 2010 | 06:02 PM
On SS you can hold the flats from turning with an open end wrench. No mangling. I have grasped the shafts on others, without flats, with vice grips, above the "washer" and under the threads, in the portion that is not contact by the damper. I also found that I left no marks.
BB4
Suspension & Brakes
Mar 8, 2006 02:50 PM
Spn_BB2
Suspension & Brakes
Jan 11, 2005 12:00 AM
[626]95-GSR
Oct 8, 2004 12:34 AM
Boost2NA
Feb 14, 2004 07:14 PM
