injectors
All four injectors are identical. Based on cylinder number, you just need to pin them to the proper ECU terminal. Do all four injector clips have battery voltage? Why do you believe that you have an injector problem?
ok another question my car was tuned on obd1 injectors, i have obd2a injectors would that make it not start?
they stole my injectors and clips
OEM OBD2 injectors have different clips than OBD1 injectors and the injector clips are not interchangeable. If that was your question/concern. If you're boosted then you won't have OEM injectors and you would need to make your own pigtails IIRC.
and i also have obd1 and obd2a injectors OEM.
i knoe i just wanna get my car running before i buy other injectors.
car was stolen so im just trying to get it back up.
no my question is ok my car had obd1 injectors and obd1 clips, ok now i have obd2 injectors and clips, does it make a difference it the ecu,
Hi. Be sure that the injectors have the same flow and the same electric oms. The injectors can be in any order but the wiring ( plugs ) have to be in the correct order.
Inyectors from b18 obd1 and inyectors from b18 obd2 may have the same flow or may not. The obd2 system is more eficient than the obd1. Sometimes have smaller injectors but a different fuel pressure regulator ( higher fuel presure ) even for the same HP.
2x0
Engine Management and Tuning
Jul 3, 2018 03:55 PM
