Guesstimate on Horsepower and stuff with my build??
Old Jul 18, 2010 | 06:44 PM
brevlle's Avatar
Default Guesstimate on Horsepower and stuff with my build??
was just seeing if you guy's would have any idea on about how much horsepower my car has...here is the build..
car is a 1990 honda civic si
engine is a jdm B16a1 dhoc vtec
tranny is out of a 90's ls integra
engine has-
8.5-1 compression ross pistons
eagle H-beam rods
ARP head studs
ported and polished head
has been bored .30 over
B&M oil cooler
power plus polished intake manifold
70 mm STR throttle body
ignition-
msd 6al ignition box
msd clear red pro cap
msd blaster ss coil
taylor spiro pro 8mm wires
turbo set up-
T3 turbonetics stage 2 polished turbo (oil cooled)
tial style external waste gate (6 lb spring)
apex blow off valve
aluminum inter cooler piping
front mount intercooler
fuel system-
walbro high volume fuel pump 255 lph-hp
DSM 450cc blue top injectors
STR fuel rail
pro fab fuel pressure regulator
apexi 2nd gen vtec air fuel computer
drive train & suspension-
clutch net sprung 6puck clutch
clutch master 7lb fly wheel
drive shaft shop 475 horse power axels
custom built 4 link style torsion bars
tokico 5 way adjustable struts
integra adjustable coilovers
drilled slotted rotors
'99 civic si wheels 15'
interior-
si seats
auto meter carbon fiber boost and oil pressure gauges
stock si in dash tach
adjustable shift light
battery is relocated to rear of car
has on off switch on rear (required if at drag strip because of battery location)
would just like an estimate on how much power i am making, as i don't have use of a dyno or anything of that sort..maybe somebody has a similar build or something?? please let me know.
Old Jul 18, 2010 | 07:10 PM
BiG ChOr!Zo's Avatar
Default Re: Guesstimate on Horsepower and stuff with my build??
save some $$$ and take it to get dyno'd
Old Jul 18, 2010 | 07:13 PM
crx_si-r's Avatar
Yup. Your gonna need to get it tuned to run properly anyway.
Old Jul 18, 2010 | 07:23 PM
ChokolAwt's Avatar
you have a built motor running 6lbs on a t3? save your next paycheck and drive to a tuner.
Old Jul 18, 2010 | 07:28 PM
brevlle's Avatar
I'm running 13lbs of boost, and I have no access to a dyno, just figured you all might have an estimate by chance.
Old Jul 18, 2010 | 07:32 PM
Gmoney400's Avatar
def get her tuned 150 miles is worth it!
Old Jul 18, 2010 | 07:40 PM
brevlle's Avatar
how much does it usually cost to get a tune? if i have enough, i will be making a trip tomorrow.
Old Jul 18, 2010 | 07:53 PM
D16SiHatch's Avatar
well you need a chipped ecu for one. if they will tune it with one of the many available obd1 rom editors then you're probably looking at a few hundred dollars easy. if they only tune hondata then you'll need that plus a tune. which could range from $500 to $1,250. high end is figuring in the cost of an s300 setup ready to go plus tune/dyno time.
Old Jul 18, 2010 | 08:03 PM
brevlle's Avatar
*****, i was hoping the answer would be like $100
Old Jul 18, 2010 | 08:05 PM
D16SiHatch's Avatar
nope sorry. have to pay to play
Old Jul 18, 2010 | 08:09 PM
EatMyVTEC :]'s Avatar
What he said. Just save up until you can go. It will definitely worth the money imo
brevlle's Avatar
yeah, figured that, just didn't figure it was THAT much, lol...i can probably find somebody around here that can help me tune, there are a bunch of cool honda guys around.
Old Jul 18, 2010 | 09:41 PM
dacrxguy's Avatar
over 9000
Old Jul 18, 2010 | 10:13 PM
Deetz's Avatar
Crazy Honda Guy
i would loose that ignition if i were you, all they give are problems, trust me!
Old Jul 18, 2010 | 10:27 PM
DumpdEJ6's Avatar
I like the tuna here
engine has-
eagle H-beam rods
ARP head studs
B&M oil cooler
ignition-
msd blaster ss coil
turbo set up-
apex blow off valve
fuel system-
STR fuel rail
interior-
si seats
I'd guesstimate approximately 180-509 WHP. Give or take a couple hundred HP. Add 50hp for each NOS sticker, too. Why do you have the interior listed?
Old Jul 18, 2010 | 10:51 PM
brevlle's Avatar
because i still had it copied from when i was sending my friend a message with all the info on it, didn't feel like highlighting and pressing backspace
Old Jul 19, 2010 | 06:20 AM
jhetz's Avatar
i made the mistake of driving on my old boosted motor without a tune and cracked a piston! it was a very expensive mistake. PA and OH have a couple guys doing dyno work that are pretty reasonable if your in that area.
everyone is right tho, you definately need a tune on that bad boy. its worth the extra money to get all the power out of the motor.
Old Jul 19, 2010 | 09:32 AM
TJChad's Avatar
If you legitimately spent all that money on this car/motor and you're worried about $1k for a tune leads me to believe either a: you have NO idea what you're doing and didnt build this car yourself or b: this is what you would LIKE to build and are trying to make everyone play a guessing game that NO ONE would be able to guess.
Old Jul 19, 2010 | 01:08 PM
brevlle's Avatar
nowhere did i state that I am the one that built it.
and i am in Montana
Old Jul 19, 2010 | 01:14 PM
lunalink's Avatar
and i am in Montana
I'm in California
Old Jul 19, 2010 | 01:38 PM
brevlle's Avatar
wanna take a trip to montana and give me a tune??
Old Jul 19, 2010 | 01:40 PM
lunalink's Avatar
Old Jul 19, 2010 | 05:34 PM
ed4_civic's Avatar
Don't matter if he has 10 of these cars......... IBTL
Old Jul 19, 2010 | 06:12 PM
roadsqueegy95's Avatar
ya deff get it tuned, i think my chipped ecu was $200 or so + $400 for dyno tune. so you looking at another $600-$1000
But you could save that money for when your motor blows, not if it does, but when it does, and you have a jump start on rebuilding it all again.
Old Jul 19, 2010 | 10:32 PM
dirtrdr22CRX's Avatar
sorry to flame!! this guys a fake!! you either just bought it, or yoru thinking about buying it!! its been on craigslist for a while that is the whole post that was listed on craigs list. word for word. he jsut omited a small paragraph and the few pics that were posted too, when i get to a computer ill link the post!! its white hatch right! on si's! yea this car is well taken car of! its been chipped and tuned already! he doesnt know what hes talking about! if you are the owner of teh car and was selling it on craigslist, i called you and wanted to buy it but you never returned my call! either way the car is fast. shut up and drive it.
