Would a 7.5 inch wheel width and +32 offset clear?
Calipers, brakes, etc? Would this be too low of an offset to run as a daily? I found some 17x7.5 +32 SSR Compeition wheels but the offset seems to be pretty low compared to other ITR setups Ive seen. What would be a good offset to run on a 16 or 17 inch wheel?
It will clear calipers just fine, but more than likely it'll hit the outside of your fenders unless you're running serious camber or have a significant fender roll.
Stick to a +42ish if you must run a 7.5" wheel.
