h/b sway bar
Old Sep 15, 2002 | 06:34 PM
solohatch's Avatar
Default h/b sway bar
does anyone have a suggestion for a aftermarket front swaybar. I just got koni adjustables but I throw the car around because it's stock height
Old Sep 15, 2002 | 06:49 PM
FourthGenHatch's Avatar
Default Re: h/b sway bar (solohatch)
You don't need a new front one. Get a 22mm Rear and you will be fine.
Old Sep 15, 2002 | 11:03 PM
solohatch's Avatar
it's a dx, I can't run a rear sway bar to be legal for SCCA classification I can only modify the front
Old Sep 15, 2002 | 11:08 PM
the DR.'s Avatar
set your konis to hard, and take off the front sway bar
i'd stick with the stock or none, depending on springs, but going thicker only in the front will make your car understeer worse
royalrebel
Suspension & Brakes
11
Dec 19, 2008 07:19 PM
DarkBB4
Feb 1, 2006 01:16 PM
MaaseyRacer
Aug 17, 2004 09:40 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
bw54867
Oct 14, 2002 06:51 PM
