94 accord 93 jdm h22 barometric pressure sensor check engine
Old Jul 18, 2010 | 12:51 AM
torieux's Avatar
Post 94 accord 93 jdm h22 barometric pressure sensor check engine
I just installed the h22 jdm on my accord and the check engine 13 (BARO) pops up and I would like to know by what it could be caused.
Old Jul 18, 2010 | 02:22 AM
GhostAccord's Avatar
Default Re: 94 accord 93 jdm h22 barometric pressure sensor check engine
Make model and year of your Accord and the year of the engine helps when trying to diagnose these types of swap problems.
It's ether the electronic control unit (ECU) or transmission control unit (TCU).
What ECU and TCU are you using, also what transmission are you using?
Old Jul 18, 2010 | 07:56 AM
phootbag's Avatar
I repaired a Baro Sensor DTC by cleaning out all of the acorns a squirrel had packed into the air cleaner box, believe it or not.
95EG2
Dec 16, 2009 07:11 PM
redds
Feb 22, 2004 06:05 AM
redds
Feb 18, 2004 10:04 PM
