Retarding timing 97 prelude?
Old Sep 15, 2002 | 06:18 PM
97grnlude's Avatar
Default Retarding timing 97 prelude?
Does anyone know how to retard the timing on the prelude? Every time i try to the ECU corrects it?
Old Sep 15, 2002 | 07:28 PM
ELUD THS's Avatar
New User
Default Re: Retarding timing 97 prelude? (97grnlude)
msd btm
Old Sep 15, 2002 | 07:44 PM
fastludeh22's Avatar
Default Re: Retarding timing 97 prelude? (ELUD THS)
theres the cheap way and the right way.
right way would be convert to obdI
a cheap way would be to do the memory wire mod. it is the power constant that goes to the memory on the ecu, you cut it and wire it to a switch. you keep the switch on off so that it forgets that the timing is changed everytime you turn the car off. the reason for the switch is in case you get a cel, you flip the switch on so you dont lose the code.
im sure sombody can elebroate on this more, but thats all i can remember.
btw-how did you turn the distributor? did you use an older model one, or did you just take the botom bolt out?
[Modified by 93ludevtec, 4:44 AM 9/16/2002]
Old Sep 26, 2002 | 10:18 AM
GraphiteAccord's Avatar
Default Re: Retarding timing 97 prelude? (93ludevtec)
you turn the distributer towards the firewall to advance it, correct?
Old Sep 26, 2002 | 10:22 AM
satan_srv's Avatar
Default Re: Retarding timing 97 prelude? (GraphiteAccord)
Turning the distributor on an 96-01 Prelude does NOTHING. The CYP (cylinder position) sensor is not in the distributor like OBDI preludes, it's down at the crankshaft in the block. Thus you can't turn the distributor to fool the CYP sensor anymore.
So it's not correcting for you, it's just dong nothing. To adjust the timing you need to reprogram your ECU, even if you do an OBDI swap the CYP sensor is in the crank so you're still up a creek.
Old Sep 26, 2002 | 10:30 AM
Default Re: Retarding timing 97 prelude? (satan_srv)
I understand the delima the 5th gen's are having, but with the 4th gen vtec, or perhaps all obd1 honda's, turning the dist. towards the firewall is advancing it, correct?
Old Sep 26, 2002 | 10:33 AM
satan_srv's Avatar
Sorry I was referring to the topic starter really, but yes that's how OBDI Prelude VTECs work.
Old Sep 26, 2002 | 11:31 AM
DsITR's Avatar
If you wanna do the OBDII "workaround" you can check it out @ntpog.org.
D
97SH
Old Sep 26, 2002 | 11:41 AM
satan_srv's Avatar
Default Re: Retarding timing 97 prelude? (dsludefosho)
That still won't allow to adjust your timing though. It will cancel out the long term fuel trim data, that's about it I would think
Old Sep 26, 2002 | 04:43 PM
Turbo Lude SH's Avatar
Doing the OBD-II work around will not allow you to adjust your timing. Like said, the CYP sensor is on the block now and not in the distributor.
Maybe convert to OBD-1 and run a OBD-1 dist and wire up the CYP sensor to up there at the dist. Or just get a MSD igntion and timing control.
CBR
Sep 18, 2004 06:21 PM
AnitRiceSuperStar
Feb 18, 2004 09:42 PM
photonjedi808
Sep 27, 2002 04:41 PM
