All Motor
Ok I need some info here. I have a D16 and would like to build an all motor. I just am not sure what that includes....sorry for being so dumb about this
I know it means its not turbo, supercharged but i dont know what i would do to build an all motor
Anyways, an All Motor setup would be a setup that is not Turbo'd or Superchared. You are most likely going to run a High Compression Pistons, and will build the Head to Rev high. You'll need to do minor fuel upgrades, aka, fuel injectors and maybe a resistor box depending on the injectors you choose.
Honestly, I'd just turbo a D-Series if you want more power for your money.
I don't know much about D-Series All Motor Builds, but I can't imigane the money/power ratio is as good as a B-Series.
boostedhatchb16a
Mar 14, 2004 01:55 PM
