f22b1vtec runs like poop. only when ECT is connected?
Old Jul 17, 2010 | 12:07 PM
njkill's Avatar
Default f22b1vtec runs like poop. only when ECT is connected?
i tested everything i could . misfireing ithink muffler smells gassy
not shure what pins on the puter i should be looking at .
ecu is a poa from a 94 accord.
please help thanx
Old Jul 17, 2010 | 02:19 PM
92civlude's Avatar
Default Re: f22b1vtec runs like poop. only when ECT is connected?
Sounds to me like the ECT is biased too cold or too hot. Have you swapped it out with a known good one?
Old Jul 17, 2010 | 03:10 PM
bseriescrxsi's Avatar
p0a is from a 94-95 accord.....might be ur problem
Old Jul 17, 2010 | 03:30 PM
nus_dogg's Avatar
x2!
I have a 5spd CB7 Accord ECU for you. PM me!
Old Jul 17, 2010 | 05:37 PM
njkill's Avatar
sorry it was a typo
94 accord.
Old Jul 17, 2010 | 06:18 PM
nus_dogg's Avatar
Ok, now that sounds more like it.
Old Jul 18, 2010 | 08:53 AM
njkill's Avatar
the tps was operaitng backwords. so i switched wires at the plug and got the right reading.
so the tps is working right.
but what pins on tthe ECU are the + and - to the tps. not the signal line.
cuz if those wires are wrong at the pins wouldent that ground out other things on that circut?
thanx again
or should i start another tapic?
Old Jul 18, 2010 | 09:01 AM
njkill's Avatar
i found a pin called tps on a ecu chart. D11 is that right .6th from the left on the D plug top row.
but what about the other 2 is that what D19-22 are for?
im not good with E-diograms
T3k C
Nov 29, 2006 04:10 PM
xwade01
Mar 6, 2005 02:45 PM
karpieldisco
Apr 15, 2004 07:52 PM
