Does rim size lower or raise the car?
Old Jul 17, 2010 | 06:35 AM
JuneBugDrfter's Avatar
Icon3 Does rim size lower or raise the car?
I have a 1990 Honda CRX. Its been lowered 2inches already. I have the stock 13 inch rims on it. I measured and the car sits 8 inches off the ground. I live on a dirt road so clearance is an issue. I have a set of 15 inch rims and tires that i wanna put on it but the concern is; Will they lower or raise my car?
Old Jul 17, 2010 | 06:42 AM
TahitianGreen's Avatar
Default Re: Does rim size lower or raise the car?
'Rim' (correct term is wheel) size doesn't have anything to do with the cars ride height, the diameter of the tire is what actually effects that. If you're 15" wheels have the correct aspect ratio for the sidewall it shouldn't affect ride height up or down
Old Jul 17, 2010 | 06:54 AM
My tire size on my CRX is 175/70R13. The tire size for the extra set of wheels are 195/60R15.
Old Jul 17, 2010 | 07:18 AM
B16-CRX's Avatar
The tires on there are 22.6 in diameter. the 15's are 24.2. It might raise the car a little if they fit in the wheel wells. check out this site...
http://www.miata.net/garage/tirecalc.html
Old Jul 17, 2010 | 07:24 AM
Cool thanks That was a useful site, B16-CRX.
Old Jul 17, 2010 | 09:30 AM
mitsubishiv5's Avatar
tire size makes a big difference on ride height.
Old Jul 17, 2010 | 12:01 PM
Pee Wee's Avatar
195-60-15 will throw off you're speedo. Technically, the are "too tall"
Old Jul 18, 2010 | 11:56 AM
sde780's Avatar
you'll prob rub a bit with 60 series. I have 55 and they still rub on hard turns
Old Jul 18, 2010 | 12:01 PM
hatchet_honda's Avatar
i bought some enkeis with 195/65/15 tires on them. wheel rubbed like a ****
Old Jul 18, 2010 | 12:16 PM
D7_62's Avatar
195/60/15's is what I have, no rub at all, yet my car has stock suspension.
Lenasec12
Sep 18, 2017 05:08 PM
apbtwhiskey
Sep 1, 2013 06:22 PM
aln2590
May 2, 2007 04:10 AM
Red_Si
Dec 15, 2003 02:16 AM
