Precision 4476e turbocharger, t4, vband
According to precision's website they don't make this turbo in the configuration you have..
300-4476 4476E Boosted 585 HP THF3-76 THF3-76W TH5876A TH6876A TH8176A TH9676A TH69076 TH85076
T3 5 bolt
.63 A/R Inducer 2.920" (58mm) Exducer 2.542" (64.6mm) Journal Bearing 3" Inlet / 2" Outlet Inducer 2.290" (58mm) Exducer 2.950" (75mm)
They make a T4 version with DBB with an .85 a/r...
300-4477 4476RE T4 OC .85 A/R Ball Bearing
T3 5 bolt
I copied that information right from the precision website. I assure you those are the specs on the turbo. For some reason the precision site isn't displaying any turbo information for me at the moment but it was on there. Here's a link to another place with all the available specs for this turbo.
http://www.nolimitmotorsport.com/prod/300-4476
oops found it.
http://www.precisionturbo.net/small-...bochargers.php
about a quarter of the way down.
300-4476
Available in t4 sizes all the way from .58 -.96ar
I assume you were looking at the 4476RE. Which is ballbearing and only available in a .85ar
300-4476
