Water In Cabin - Passenger Side
I am getting water on the passenger side when I drive...
I was told my AC drain is clogged, I was wondering if anyone has any pictures or information on where I can find this for 2001 Honda Civic.
How much fluid is collecting on the carpet? Does this happen when it's raining, or only when your AC is on?
Remove the passenger lower dash cover under the glove box. Just pull down on the front of it. Look around with a flashlight to see if you can tell where the liquid is coming from. If it's only a small amount of moisture, it might just be dripping from the evaporator.
i used to own a 90 accord, i too had a water leak. thought the car may be rusting out underneath or something. turns out it was because my weather stripping around the doors had been worn out and gone bad. so whenever it rained water would run down the window and inside of the door then on to the floor. so maybe check that out too?
enzqt
Apr 23, 2015 12:06 PM
thekid2390
Jun 30, 2013 12:15 PM
darkestfenix
Jun 24, 2010 09:36 PM
