Clicking after headwork
Old Jul 16, 2010 | 03:03 PM
DeLucious's Avatar
Default Clicking after headwork
I got new valves installed and the head resurfaced on my B16a3. The shop replaced the guides too. So the head is installed and we do the timing and adjust the valves to factory spec and its making a clicking noise. It sounds liek the valves. Also the engine is sluggish and isn't as quick as it used to be. The valves have been readjusted 4 times. We even tried to adjust them to half of factory spec. They still click. I searched online, but could find no answer other than adjust the valves. What could be causing this?
Thanks in advance for the help.
Old Jul 16, 2010 | 05:11 PM
Str8EJ's Avatar
Default Re: Clicking after headwork
did you check all of your lost motion assemblies?
would take only one bad one.
Old Jul 16, 2010 | 06:03 PM
DeLucious's Avatar
How would I check that? I dont even know where that is.
Old Jul 17, 2010 | 11:34 AM
Str8EJ's Avatar
LMAs are located in a recess between each pair of valves. There are eight of them total, centered on the middle, high-lift lobe of the camshafts, which have to be removed for access. Wouldn't explain the poor performance.
Do you have a factory service manual?
Old Aug 2, 2010 | 05:18 PM
DeLucious's Avatar
OK. So I know that the clicking is the LMA's. But would anybody know what would make it sluggish and backfire?
Old Aug 2, 2010 | 05:24 PM
EJeff8's Avatar
Sure the timing is correct?
Old Aug 4, 2010 | 01:34 PM
DeLucious's Avatar
Yes. The timing is perfect.
menfou
Honda S2000
May 17, 2011 05:48 AM
HondaKing90
19
Feb 15, 2010 04:38 PM
loc_yaj
Apr 12, 2008 06:40 PM
onyx00
Feb 24, 2002 01:32 PM
jdmhondageek
Jan 25, 2002 08:52 PM
