Could the cause be hot weather?
Old Jul 16, 2010 | 11:17 AM
justdoinme23's Avatar
Default Could the cause be hot weather?
ok....well when i pull out or sitting stilll my idle drop's it feels like i have the ac on but i dont...but us civic owners kno wats that feels like...and it feels likeit lags wen i pull out till i get to about 4k rpms...and thoughts....turn idle up? vacuum leak...i did out a new alt. in about 3 weeks ago..but its been really hot and muggy in PA....any suggestions would be kool
Old Jul 16, 2010 | 11:19 AM
EJeff8's Avatar
Default Re: Could the cause be hot weather?
any Cel?
Old Jul 16, 2010 | 11:23 AM
yea..i kno it runs rich, besides that havent had the codes checked....gets inspected this month.....but the check eng lights been on and it just started doin it...it used to ilde at about 1300-1500 now about 500 rpms, and i gotta rev it now a few time to pull out...thats why im think hot weather...suggesions
Old Jul 16, 2010 | 01:40 PM
EJeff8's Avatar
Just because its been on doesn't mean you don't have others that have popped up. Check them yourself or run to autozone
Old Jul 17, 2010 | 09:21 AM
2 codes...p0135 a/f sensor p1122 thro. pos. sensor...guessing they prolly have to do with bad idle...also tho my buddy said after i put in my itr cams my timing could be off causing it....but we will se after i replace sensors
Old Jul 17, 2010 | 09:29 AM
EJeff8's Avatar
^ what? You're going to replace the physical sensors? That's not how you fix sensors. They could be bad, but sensors go off when something is wrong in the car, they are much more unlikely to go bad. Find out WHAT is making the sensors go off. And yes, your timing could be off. Check it with a timing light.
Old Jul 17, 2010 | 02:33 PM
ok...well would would cause my car to run rich...unless a bad sensor....wat fuel pressure is good for a b16...maybe the cause...shoulda statred a new topic, but same generalized discussion
brant
Mar 29, 2011 06:43 PM
phil04
Aug 5, 2010 04:40 PM
mystikal-vti
Dec 26, 2008 11:58 AM
Platinum.Skillz
Sep 28, 2007 03:33 PM
civicdohc
Aug 27, 2004 10:13 PM
