GSR swap...Suspension???
Old Jul 15, 2010 | 10:43 PM
ultima4300's Avatar
Default GSR swap...Suspension???
hey im droppin a GSR motor in my EG and i dont know if i should just go cheap and just get OEM suspension all around for GSR motor or if i can find a decent set of full coilovers or something for around 200 bucks.... any ideas? still a little new to the scene so trying to lean as much as i can
Old Jul 16, 2010 | 04:18 AM
H22*CiViC's Avatar
Default Re: GSR swap...Suspension???
You should never go cheap for any part of your build bc it will be a headache in the long run. i would go with full coil overs but they are hard to find for around 200 dollars but if u dont have the money to buy them new or almost new condition than stay with ur stock suspension bc it not worth wasting 200 dollars now and than having to buy a new suspension in a couple month.
Old Jul 16, 2010 | 06:08 AM
Vindicator9000's Avatar
318 Curves, 11 miles
200 is not enough for aftermarket suspension mods, especially when you figure that you'll have to pay $75-100 to get it aligned afterwards. Yes, you can get parts that cheap, but they're not worth putting on your car.
You can pickup used ITR springs relatively cheap from hmotors and run them on stock shocks, but it'll be stock ride height.
Old Jul 16, 2010 | 06:16 AM
reality's Avatar
I went with a $1000 suspension hook-up but people its too much for a civic. Full coilover suspension lifetime warranty.
Old Jul 16, 2010 | 02:25 PM
ultima4300's Avatar
aight aight thanks a bunch! ill just go stock for now i just need to find the rear OEM gsr suspension cause i got the front.. and ill just do like u guys say and just save up for some tiens or somethin thanks again
Old Jul 16, 2010 | 07:09 PM
thumper64's Avatar
Just piece something together as you go. Check out the marketplace, someone is bound to have some H&R, Tein, Eibach, something decent. Help the community if you can...
Lindsey Morton
Mar 24, 2018 05:44 AM
Theocide
Feb 10, 2017 07:21 AM
slimjimdanny
Suspension & Brakes
Feb 25, 2007 02:48 PM
littlegreenb18
Sep 23, 2005 09:59 PM
flow_azn
Nov 30, 2004 11:01 PM
