car doesn't start
Old Jul 15, 2010 | 09:24 PM
K3V1NwasH3R3's Avatar
Icon3 car doesn't start
ok so today we finished installing all the parts(throttlebody(dont have map sensor),injectors,fuel rail,fuel pressure regulator,valve cover) and we went to turn it on but doesnt start
the car does :
crank
turn over but doesnt start
we bought carburetor starter spray
it only turns on if the hold the gas and if we us carburetor starter spray
but doesnt stay on
my ideas wat maybe doesnt work
injectors are bad
or idle is wrong (i bought it not new so idnt if they messed wit the idle)
SOMEONE HELP ME!!!!!! PLEASE!!!!!!!!!!!!!S.O.S
pm or text me 732 604 6362
Old Jul 15, 2010 | 09:26 PM
RedHatch00's Avatar
Default Re: NEED HELP ASAP!!!!!! SOME ONE HELP ME S.O.S
stupid question but did you check all your sensors
would i need all sensor to start the car at all??!?!?!?!
Old Jul 15, 2010 | 09:28 PM
dude i need all the help i can get there is never a stupid question
Old Jul 15, 2010 | 09:32 PM
Former User's Avatar
Your title says nothing specific about your problem. You should change it.
doesnt stay on
What exactly does this mean? Be clear.
Old Jul 15, 2010 | 09:33 PM
i knoe i was about to change it after i red the other post
Old Jul 15, 2010 | 09:41 PM
Default Re: car doesn't start
That's a much better title.
Does the engine fire up with starter fluid?
What does this mean "only turns on if the hold the gas"?
Old Jul 15, 2010 | 09:44 PM
b18cKoupe's Avatar
so you're trying to see how the car runs with no map sensor?
Old Jul 15, 2010 | 09:45 PM
Hondatherdm's Avatar
it needs map sensor to run
Old Jul 15, 2010 | 10:08 PM
if i can they yeah or do i need it to run?
Old Jul 15, 2010 | 10:10 PM
You need the MAP sensor connector and working.
Old Jul 15, 2010 | 10:12 PM
the connector or the sensor u just confused me
Old Jul 15, 2010 | 10:23 PM
Edit:
You need the MAP sensor connected and working.
Old Jul 15, 2010 | 10:26 PM
Edit:
ite thanks Honda tech members !!!!!!!
Old Jul 16, 2010 | 12:53 PM
BUMPPPPPPPPPAPPSSPSPSP HELPPP
Old Jul 16, 2010 | 01:50 PM
Instead of bumping, read about how important the MAP sensor is. This will compel you to get one and hook it up.
Old Jul 16, 2010 | 05:27 PM
Dude why you even mess with that sensor, it tells ecu IM vacuum your, fuel trims are calculated from MAP, its the most important sensor on hondas and no your car wont run with out it, it needs to read vacuum, put it where it needs to be from factory and dont touch it
Old Jul 16, 2010 | 06:44 PM
bro my **** got stolen so im rebuilding it , i didnt knoe but thanks ima go buy that **** tomorrow,
Old Jul 16, 2010 | 06:57 PM
THANKS THOOO SORRY IM JUST NEW TO THE HONDA GAME AND ITS MY FIRST CAR IM ONLY 17 SO YEAH I KNOE ALIL ABOUT CARS NOT EVERYTHING THO
Old Jul 16, 2010 | 10:22 PM
i didnt know about your s*** getting stolen part
Old Jul 16, 2010 | 10:25 PM
yeah bro im doing the after math now trying to get it up and running
Old Jul 17, 2010 | 08:15 PM
GOT THE SENSOR TONITE!!!!!! WOOT WOOOT GONAA TRY IT TOMORROW BRIGHT AND EARLY
Old Jul 18, 2010 | 04:26 PM
GOT SENSOR < TESTED INJECTORS ARE BAD!!!!!!!
Old Jul 19, 2010 | 11:02 AM
cat still doesnt start
Old Jul 19, 2010 | 11:14 AM
Spark, fuel, CEL codes?
