99 Accord short ram intake recommendations?
Old Jul 15, 2010 | 06:54 PM
jammwill's Avatar
Default 99 Accord short ram intake recommendations?
Can anybody recommend a good, cheap short ram intake with filter for a 99 Accord EX 2.3? I appreciate it!
James
Old Jul 15, 2010 | 08:51 PM
fastlane2's Avatar
Default Re: 99 Accord short ram intake recommendations?
FYI try FAQ or just ebay and AEM filter
Old Jul 16, 2010 | 03:16 AM
jwicecold's Avatar
James
Why go short ram?? you can get full length for same price and your car will have a better chance of sucking in fresh cold air instead of hot engine bay air!.. Also all cold air intakes are the same so you can just buy one on ebay for 35$.
Old Jul 16, 2010 | 06:07 AM
jammwill's Avatar
Thanks guys I appreciate the advice.
Old Jul 16, 2010 | 06:21 AM
GhostAccord's Avatar
When your car is on the highway or cruising down the road. A SRI will not be sucking in vast amounts of 100°C air. The ambient temps under the hood may be a bit warmer but not much.
For example, I ran my Accord with a SRI and monitored the intake air temp sensor. The temp only varied by 10-15°C over the outside air temps. Yes it is a bit warmer but unless you need .01 second to win the 3120. It's not a big enough temp differential. Not to mention the higher temps are probably more due to heat soak from the cylinder head into the intake manifold than outside air.
X2 on buying an Ebay 3" intake tube and then using a reputable cone filter on it.
75aces
Jun 9, 2022 04:19 PM
eagleclawracing
May 25, 2006 07:54 PM
IntegraTypeRob
Jul 27, 2005 05:06 PM
Mondori
Aug 27, 2004 05:42 AM
BearAccordEX
Nov 12, 2001 05:02 PM
