Went to Cali Speedway today
Old Sep 15, 2002 | 04:29 PM
Vanilla4215's Avatar
Default Went to Cali Speedway today
First time at the track today. I have a 92 cx with a b20 block with JE 11.0:1 and a stock gsr head, CTR tranny, I/E, ACT 6 puck, fuel pressure regulator, and fuel pump. 1/4 tank of gas, and no back seats, spare, or jack. Running on 14" blackies, with some cheap *** tires. These times seem like they could have been better, but oh well.
R/T ... .828
60' ... 2.256
330 ... 6.111
1/8 ... 9.241
MPH... 79.05
1000...11.948
1/4 ... 14.259
MPH... 96.03
I ran a couple of times like this. I also tried using my 15" rotas with Azenis tires, but I got way too much wheel hop. I would like to hear your comments.
Old Sep 16, 2002 | 08:33 PM
slooowDX's Avatar
Default Re: Went to Cali Speedway today (Vanilla4215)
hmm not bad, get some slicks or set your suspension up really good... i run consistant 14.4's on azenis w/ my B18C powered 92 DX...try it w/ some slicks, you can prolly dip 13's
Old Sep 17, 2002 | 09:35 AM
Default Re: Went to Cali Speedway today (slooowDX)
I was thinking that my times should be faster then this, even without slicks. I thought that I should be getting some high 13's on street tires, but yeah I do need to stiffen up the rear suspension. It dips down a lot on the launch. After I ran with the azenis and switched then I noticed that they melted a little. Has this happened to you?
Old Sep 26, 2002 | 04:14 PM
slooowDX's Avatar
melted?? nah... were you doing burnouts? i didnt want to but they made me go through the water, but as far as the tires melting...naaahh...mine were fine
Old Sep 27, 2002 | 12:38 PM
They didn't melt a lot. Just a little. I also had a bunch of little rocks all over the tire that stuck to it because of the heat on the tires after the run.
Old Sep 28, 2002 | 06:44 PM
Default Re: Went to Cali Speedway today (2000integragsr)
Check http://www.californiaspeedway.com
Soda Popinski
Nov 21, 2005 07:24 AM
slowsleeper
Oct 20, 2004 02:55 AM
SprayinCX
Mar 29, 2004 03:36 PM
FusionEg6
Aug 19, 2003 06:57 PM
BackSideSA
Mar 31, 2003 06:28 PM
