Window Regulator Handle
Old Jul 15, 2010 | 04:52 PM
jash's Avatar
Default Window Regulator Handle
Hello all,
I am having an issue with my window handle crank on my 96 dx. The handle appeared to be disconnected and it wouldn't roll up window. I removed the door panel and the part which connects to the handle (long nubbin device with gears at the end) seemed to detach from the teeth on the regulator. I found the nut on that connects that long nubbin device to the regulator came off, and I also found this plastic washer thing I have no idea where it goes (pic below). You can see the plastic piece all chewed up and warped.
Now I have been scouring the net for a part diagram of a manual window regulator, but I cannot for the life of me find anything with any semblance of detail. I know the regulator itself is fine, it's just the handle piece with gears became disconnected due to the nut or washer. Any help I can find here would be much appreciated.
jim109
Jul 5, 2010 06:24 PM
bopbop93030
Nov 20, 2008 09:03 AM
blasintebo
Dec 11, 2005 03:51 PM
Jonathan_ED3
May 9, 2005 11:42 AM
out_of_order
16
Jul 26, 2004 10:06 PM
