RPF1's 15x7 +35 or +41?
Old Jul 15, 2010 | 03:24 PM
choadsi's Avatar
Default RPF1's 15x7 +35 or +41?
Looking to get some enkei's and run a 225 50 15 drag radial.
Needing help on what offset would work better 35 or 41.
I am not trying to slam my EM1 but I will go a little lower than stock.
Any advice would be great, also need advice on which drag radial brand to use.
I was looking a BFG drags but have heard good things about MT.
Old Jul 19, 2010 | 08:32 AM
choadsi's Avatar
Default Re: RPF1's 15x7 +35 or +41?
wow ok 100 views and nothiing. I guess i will add more info then to better explain my issue. I would like my 99 si on enkei rpf1's with a +35 offset on a 225/50/15 drag radial. I have read other threads stating that the 225 accel. slow and that to use a 205. Either or would be nice i am trying to get 550+ to the ground and stick. Yes Yes i know that over 450 on a 225 you are lucky to get anything to stick so what i mean is i want something to stick very well or the best out there. If it be a 205 then ok but i think the 225 will be the better choice. I don't care about the accel problem cause i think that if the hp gets out there then to car will accel fast enough.
I also know that you can't tuck the 225 as i do not want to for daily issues(and no this will just be a weekend warrior) but if i did want to go lower than that i would have to roll my fenders yes?? and use a spacer?? I am aware that Drag Radial don't last long i again do not care. The back will hold a 205/50/15 normal road tire and will not be rotated at all or course with the drags in the front.
I read the other thread asking about the 225 and just got a bunch of gearing statements out of it. So if anyone has any ideas or advice on this issue please post up. I am eager to hear them.
Choad
Old Jul 20, 2010 | 09:30 AM
Cooper The Tire Rack's Avatar
225/50-15 is .5" taller than the tallest tire we recommend for that car. It is also 20mm wider than recommended. I would stick with 205/50-15 with the RPF1 in ET41.
thorclark
Feb 5, 2009 10:27 PM
TypeSLO
Sep 23, 2008 12:52 PM
401tuner
Nov 4, 2007 12:45 PM
ej1252
Oct 22, 2007 09:18 AM
Louie
Sep 2, 2001 10:10 AM
