ok one more question about installing jdm steering wheel
Old Sep 15, 2002 | 04:22 PM
B00STeD's Avatar
Default ok one more question about installing jdm steering wheel
what do i do with this line?? the one that my hand is on.
Old Sep 15, 2002 | 04:33 PM
zer0zer0 TypeR's Avatar
Default Re: ok one more question about installing jdm steering wheel (B00STeD)
i had the same damn problem. i just cut the damn wire. i know that was stupid but **** my wheel works fine.
Old Sep 15, 2002 | 04:34 PM
B00STeD's Avatar
Default Re: ok one more question about installing jdm steering wheel ('00TypeR)
thats hwta im debating on doing now but anybody else have any ideas?
Old Sep 3, 2004 | 10:35 PM
Seedc2's Avatar
im on this step here. I was about to pull the srs reel off but uh.. im stuck in the same exact place (pictured above) Do i cut those wires? or is there a way to pull them off.
and how would I install the horn? tried searching like a mad man but havent come up with anything significant for my application (98gsr)
Old Sep 3, 2004 | 11:56 PM
uNF$@#!'s Avatar
Default Re: ok one more question about installing jdm steering wheel (kendogg)
I think thats part of the srs reel, if i remember right from the last install i saw. follow the wire and it will plug into a yellow connector i think . you can disconnect it there.
Old Sep 4, 2004 | 12:01 AM
Seedc2's Avatar
Default Re: ok one more question about installing jdm steering wheel (w@@t w@@t)
okay i got that part.
is it possible to install the horn? I dont see any possible way for this to happen after i disconnect the srs reel
how do you wire the horn for the jdm itr non srs steering wheel?
Modified by kendogg at 1:53 AM 9/4/2004
Old Sep 4, 2004 | 10:29 AM
Seedc2's Avatar
bump
Old Sep 4, 2004 | 01:40 PM
Saga's Avatar
You have to hook up a shoe horn behind the steering wheel hub. This is available at your local honda dealer. I wish I have the part number here.
IM Mike M or len, they should be able to help you out.
Old Sep 4, 2004 | 02:14 PM
six_speed's Avatar
you can buy a shoe horn or make one.
find a flexible 1 1/2 by 1/4 inch condutcing medium (aluminum is easy to bend.)
or have any size aluminum piece that's long enough to touch the back of the itr non-srs steering wheel(remember to put all purpose grease behind the wheel as the aluminum will be touching it.. It's going to bolt up to one of the screw bolt the srs reel bolts too.
Find the horn wire and hook it up to the aluminum piece and bolt it up to one of the scew point(may need to drill a hole.)
i hope that's understandable and have fun.
Old Dec 12, 2004 | 09:31 PM
FULL throTTLe's Avatar
Default Re: (Humping_dragon)
this **** is harder than you think it is..
Old Dec 13, 2004 | 06:36 AM
uNF$@#!'s Avatar
Default Re: (FREAKnasty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FREAKnasty &raquo;</TD></TR><TR><TD CLASS="quote">this **** is harder than you think it is.. </TD></TR></TABLE>
you best take your junk into the dealership then.
Old Dec 13, 2004 | 07:48 AM
bus stop's Avatar
Default Re: ok one more question about installing jdm steering wheel (sim shadeee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by kendogg at 1:53 AM 9/4/2004</TD></TR></TABLE>
after you disconnect that srs reel from the Yellow Connector deep under the steering column......u can "hot wire" an electrical wire up from there ( to test if it work....just "touch" the wire into any metal and the honk should sound) pull the wire up to the top of the steering column....connect it with a thin steel wire....use some screw to secure the steel wire on those plastic......then make sure the steel wire will have contact with the bottom of the steering wheel when u put it down.
that's how I did mine...hope it help.
Old Dec 13, 2004 | 11:54 AM
revvin9k's Avatar
Default Re: ok one more question about installing jdm steering wheel (Saga)
Instead of a shoe horn,which is great if you have one handy, I just used a paperclip. Works great.
youngen
Jan 15, 2008 05:40 PM
Lamska
Jul 8, 2004 05:45 PM
XSSIVE
Dec 3, 2003 08:21 AM
TypeR1558
Oct 3, 2002 09:37 PM
