Tanabe Rear sway bar question
Old Jul 15, 2010 | 01:43 PM
Rand The Man's Avatar
Default Tanabe Rear sway bar question
I have one now acquired everything needed to install and went to bolt it in and if the bushing are against the brackets they would be stock and the links sit about 4-6 inches away(sorry didn't bother to measure it. has anyone done one to their car if so did you just have to bend the brackets back or what? Thanks, Randy.
Old Jul 15, 2010 | 02:45 PM
civiccrx's Avatar
Default Re: Tanabe Rear sway bar question
They bolt right up without mods. This is a picture of a tanabe resprayed in grey. Is your bracket backwards?
Old Jul 15, 2010 | 04:46 PM
I had to buy after market ones from a local race shop its energy suspension bushings that looks like the one I have though whats the diameter of your bar?
Old Jul 15, 2010 | 07:42 PM
civiccrx's Avatar
Standard 20mm tanabe stabilizer on this guys car.
Do you have the endlinks for it?
Old Jul 15, 2010 | 09:35 PM
Yep thats exactly what the race shop said, and yes I purchased brand new ones from napa.
Old Jul 15, 2010 | 09:43 PM
I forgot to mention I have skunk2 LCAs
Old Jul 16, 2010 | 07:41 AM
civiccrx's Avatar
Take a few pictures of what you're dealing with. You should not have to bend any brackets.
Old Jul 16, 2010 | 01:19 PM
acmoc's Avatar
I have one, check my sig
Its an easy bolt on
Old Jul 16, 2010 | 02:16 PM
civiccrx's Avatar
Its an easy bolt on
You build is thread really doesn't show anything new here dude. It is a direct bolt on though, that's true.
He has a DX which means that he had to source a few additional parts to bolt this up, such as the brackets, lca's, and endlinks. This is what makes me think that he mounted the bracket on backwards, because it would make it look like it is short by a few inches if it was.
Old Jul 16, 2010 | 02:49 PM
Alright i had to slightly pull back the bracket so it fit firmly but its going to have to sit a little bit higher than it would with the stock bushings but if I put the sway bar a little bit higher on the bracket is it going to hurt anything???
Old Jul 16, 2010 | 05:34 PM
civiccrx's Avatar
A little bit is probably normal since the car is raised and the suspension drops when it's lifted.
Old Jul 16, 2010 | 09:55 PM
WOOO! It's on and my car is handling and turning better than ever thanks guys I'll try and get a cam to take a pic!
Old Jul 16, 2010 | 11:17 PM
civiccrx's Avatar
If you have a B16 +, you'll love the addition of a tanabe front stabilizer. Handles like a bitch with it!
Old Jul 17, 2010 | 08:46 AM
Well in my eyes my car is set with suspension. The only things I'm missing is the rear lower tie for the LCA's and the upper tower bar for the front, I already have the lower, I have the front and rear tanabe swaybars and OMNI coil overs all the way around. At the end of this month I'm pulling my d15b2 out and unless my buddy decided to get his SI worked on, were probably just going to drop it into his car. I'm just going to clean up my engine bay send the car out for paint while I rebuild the lower half of the block myself put some different pistons in it I building it for a b16turbo. Idk what anyone thinks or says about my ride! My car is the **** to me! It sucks cause the only body work on my car that needs to be done is the roof sometime between the early 90s and now the hood flew up dented the hell out of the roof.....oh well other than that shes real purdy for being flat blacked!
Old Jul 17, 2010 | 09:11 AM
civiccrx's Avatar
Awesome! Keep it up. With the heavier engine, I liked the feel of the tanabe 26mm front stabilizer.
Ephekt
Suspension & Brakes
Dec 20, 2012 02:43 AM
CCCP-ef
Suspension & Brakes
Sep 19, 2007 11:25 PM
dkrex001
Mar 3, 2007 09:48 AM
civais
Suspension & Brakes
Mar 9, 2005 12:53 PM
essex
Apr 14, 2003 10:54 AM
