Speedometer/Odometer Don't Work
Old Jul 15, 2010 | 12:47 PM
NJ_Brian1998EX's Avatar
Default Speedometer/Odometer Don't Work
Hi guys, my speedometer will go to 20mph no matter how fast I am going and not move, but then maybe once a week will work just fine. I am told to lube up the cable on the end that attaches to the transmission. Would that be the most likely solution? Thanks
Old Jul 15, 2010 | 12:50 PM
Former User's Avatar
Default Re: Speedometer/Odometer Don't Work
Your speedo is unlikely to have a cable.
Any CEL codes? I think it more likely to be a speedo problem, though you should also test the VSS and its plug and wires.
Old Jul 15, 2010 | 12:54 PM
EJeff8's Avatar
Your Speedo system is electric so no cable. But it seems like your problem is mechanically, as in the cluster itself. You may need to invest in another one.
Old Jul 15, 2010 | 01:07 PM
92lxsleeper's Avatar
if you have a cel (the vss is not working whatsoever.)
if the vss checks out good (check resistance while spinning with a drill) it is likely the PCB on the back of the speedometer. just swap in another speedo, or board and you will be good to go.
Old Jul 15, 2010 | 02:51 PM
Budget Racer's Avatar
I had a bad battery once after swap and the speedo, and headlights stopped working. Sounds weird but its true. Check your battery is just one option.
GPC91
11
Sep 12, 2012 07:33 AM
9.3.S.I.L.U.D.E.
Oct 6, 2010 09:52 AM
949
14
Aug 23, 2010 10:43 PM
Clash0901
Jan 16, 2010 01:23 PM
turbo-crx
Oct 20, 2008 12:05 PM
