My car died at 7000 rpm
Old Jul 14, 2010 | 09:35 PM
johnhancock's Avatar
Default My car died at 7000 rpm
So I just swapped an f20b into my cb7 accord
and I was driving it a few days after, I was in vtec at 7000 rpm and it just shut off
I haven't been able to start it since the only light on the dash thatccomes on is the battery light no engine code the engine light doesn't come on when the fuel pump should be priming and I can't hear it priming
I tries the main relay and that didn't work I checked all the grounds and they are tight the engine does crank but it won't start does anyone have any ideas?any help would be greatly appreciated
Old Jul 14, 2010 | 09:46 PM
bseriescrxsi's Avatar
Default Re: My car died at 7000 rpm
3 components of combustion are air fuel and spark.....start there n see if your getting thm
Old Jul 14, 2010 | 10:40 PM
02 accord's Avatar
If the CEL doesn't go on, the ECU probably isn't giving fuel either. Check the ECU fuse.
Old Jul 15, 2010 | 07:29 AM
I checked the ecu fuse and that's not the problem either
I did find a few exposed wires one from my vtec pressure switch and the others on my speed sensor so I'm thinking something couldn't shorted
Old Jul 15, 2010 | 01:30 PM
4671 Hybird's Avatar
If you pull the injectors and crank the engine, are they spraying fuel? What about spark, are you getting that while you're cranking?
Old Jul 15, 2010 | 03:51 PM
So I checked for fuel and I checked for spark and I don't have either I tried another ecu and that wasn't the problem either
Old Jul 15, 2010 | 05:30 PM
I also just changed every fuse in my car and it's still doing the same thing only the battery light comes on fuel pump doesn't prime and main relay doesn't click no fuel and no spark
Old Jul 15, 2010 | 05:34 PM
phootbag's Avatar
Probably coincidence that you were at 7kRPM. Look for a poor power or ground connection.
Old Jul 15, 2010 | 08:48 PM
Blackczar22's Avatar
How do u know if the fuel filter is going bad??
Old Jul 15, 2010 | 08:52 PM
hondatyperlove's Avatar
KeeshaunaG7
Nov 21, 2014 06:36 PM
JdmRex805
19
Nov 20, 2014 05:23 PM
tweekdb17
15
Feb 3, 2010 07:20 AM
saxman
16
Aug 26, 2005 10:00 AM
