Can't remove tranaxle after all bolts removed, what now?
Old Jul 14, 2010 | 08:58 PM
Speardog's Avatar
Default Can't remove tranaxle after all bolts removed, what now?
I have a 96 civic hx 5 speed. I am in the process of removing the transaxle to replace the rear main seal. I have everything disconnected and cannot for the life of me remove the housing. it is about 1 inch separated from the engine but hung up. Does the input shaft get hung up this bad??
Any input is appreciated.
Jeff
Old Jul 14, 2010 | 09:41 PM
goldpearleg6's Avatar
Default Re: Can't remove tranaxle after all bolts removed, what now?
wtf is a transaxle do you mean transmission did you remember to remove the dust plate
Old Jul 15, 2010 | 01:10 AM
hatchet_honda's Avatar
alll mounts off?? perhaps its stuck on the dowel pins
Old Jul 15, 2010 | 05:13 AM
Vindicator9000's Avatar
318 Curves, 11 miles
On a front wheel drive, it's technically called a transaxle. It even calls it that in the manual. Most people just call it a transmission.
x2 check the dust plate.
They can be a little tough to separate. I remember having to go around it with a prybar the last time I had mine off.
Old Jul 15, 2010 | 05:41 AM
Markley02's Avatar
+1 for the dust plate! After fighting with mine for 10 minutes it was the ultimate DUH moment.
Old Jul 15, 2010 | 07:25 AM
farfrumugen's Avatar
on all fwd vehicles "transmissions" are actually transaxles, and by all means should be referred to as such. even i sometimes call them transmissions for sake of people understanding me but all in all its wrong terminology to call them transmissions.
adam
Old Jul 16, 2010 | 07:21 AM
Speardog's Avatar
It was the dust plate!. I didn't think it required removing to remove the transaxle. Thanks for the tip. It was even more of a PITA to put it back on!
Jeff
JusAccord
Jul 17, 2011 07:36 AM
superman3503
Suspension & Brakes
May 25, 2006 08:15 PM
dwtyper
Dec 30, 2002 07:24 PM
