FT: WV EG hatch built lsvtec n/a trade for sedan/coupe
This is a fully running lsvtec long block with 210 compression straight across. the rings were built on a little lose side. when in vtec it burns a little oil. lose about 1qt of oil every oil change. the block has around 35k. i used this motor in couple of 7hr car trips before. it has no problems.
im looking to trade this hatch w/ built motor for a 96-00 civic coupe/sedan or integra w/ stock motor. i would perfer it having sunroof. AC is a must have. also may consider a 92-95 civic sedan if its really clean
B18b1 bottom end
11.5:1 CP piston
eagle rods
B17 GSR head
Supertech dual valve spring
Titanium retainers
Blox Type C cams
ITR intake manifold
MaxBore 66mm LS Tb
Full Race Cam Gears
custom shortram intake w/ filter
JDM **** 4-1 Header (mugen copy)
s2000 injectors
LSVtec oil kit
Neptune Tuned chip
the hatch details
1994 Civic Cx w/ 130-140k miles
Built N/A LSVTEC 219/154tq
B16 tranny no grinds
ACT Extreme street clutch
7lb Flywheel
p28 chipped
GSR cluster
glow shift oil pressure gauge
Tenzo R lowering springs on stock struts. 2.5" drop
13" stock steelies with tires (does not come with the purple steelies in the pics)
walbro 255 fuel pump
fuel pressure gauge on fuel filter
Manual cutout with a wire to lock on inside the car
viper alarm system w/ remote but lcd screen is broken
fresh inspection sticker
as for details on my hatch... it has a clean title. also has a good bit of honda cancer on both side. a truck also side wiped the rear driver side while backing up... its missing the rear carpet in the trunk. NO AC OR PS. also it needs a new cable that controls the coolant that runs into the heater. the cable got bent. so if you want heat. you would have to manually open up the valve in the engine bay. it will stay there til you decide if you want to have cool air coming in. i can show you this if you plan on trading me.
for the pass 6years or so i daily this car without any problems.
Does not come with the yellow top. i have another battery for it. that came from advance auto.
the door lock rods are messed up on the driver side. not sure whats going on there . i havnt really taken a look at it. i had power locks from the viper alarm system. i think it may of bent or broke one of the plastic parts that hold them together. but it locks perfectly fine with the key. both sides are missing the plastic lock/unlock lever thing. it broke off from the power locks. pretty cheap fix if you want this fix this.
http://i42.photobucket.com/albums/e3...o/43d86642.jpg
http://i42.photobucket.com/albums/e3...o/21075680.jpg
as for the headunit i plan on keeping it and i will include the oem headunit if i can find it.
also has front pioneer speakers or maybe another brand. i have to take a look at it sometime. its not factory for sure since i took those out.
it needs a new hood release or you can use a vice grip or something to tie around the wire to make it work. the cable broke off the plastic lever
the rear window struts has been removed since the plastic socket thing that holds it in place broke off.
if i left any details out. just reply here or shoot me a pm
heres the link to my dyno on ht
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/81m-lsvtec-w-blox-c-cams-new-numbers-2658758/
http://i42.photobucket.com/albums/e3..._SherGSR-1.jpg
http://i42.photobucket.com/albums/e3...4/45b90af0.jpg
http://i42.photobucket.com/albums/e3...ip1234/rpm.jpg
http://i42.photobucket.com/albums/e3...o/10deaad7.jpg
http://i42.photobucket.com/albums/e3...o/b7769279.jpg
http://i42.photobucket.com/albums/e3...o/60531b26.jpg
http://i42.photobucket.com/albums/e3...o/b7eb1364.jpg
http://i42.photobucket.com/albums/e3...o/849b6dd8.jpg
http://i42.photobucket.com/albums/e3...o/dc06352b.jpg
http://i42.photobucket.com/albums/e3...o/66a709ad.jpg
http://i42.photobucket.com/albums/e3...o/8189d7a5.jpg
http://i42.photobucket.com/albums/e3...o/1e63cbf5.jpg
http://i42.photobucket.com/albums/e3...o/2075baab.jpg
http://i42.photobucket.com/albums/e3...o/cc5bf7f6.jpg
http://i42.photobucket.com/albums/e3...4/IMG_0027.jpg
http://i42.photobucket.com/albums/e3...4/IMG_0026.jpg
http://www.youtube.com/watch?v=QNMWP2HoyiU
http://www.youtube.com/watch?v=a4q-CfL70OA
http://www.youtube.com/watch?v=VZiLh_TjhYM
aim sn - sheryip6786 probably the easiest way to reach me
morgantown,wv 26505
B18b1 bottom end
11.5:1 CP piston
eagle rods
B17 GSR head
Titanium retainers
Blox Type C cams
ITR intake manifold
MaxBore 66mm LS Tb
Full Race Cam Gears
s2000 injectors
LSVtec oil kit
Neptune Tuned chip
the hatch details
7lb Flywheel
p28 chipped
GSR cluster
morgantown,wv 26505
komat
Jul 25, 2010 08:32 AM
komat
Mid-Atlantic (Sales)
Jul 14, 2010 12:08 PM
BLK JDM
May 20, 2004 07:29 AM
