What wheels fit 11" Fastbrakes or Wilwood front brake kits
Old Jul 14, 2010 | 07:04 PM
bigchris2000's Avatar
Default What wheels fit 11" Fastbrakes or Wilwood front brake kits
I was wondering what wheels will work with the 11" Fastbrakes or Wilwood front brakes?
15s or 16s. Thanks for any help.
Old Jul 14, 2010 | 08:42 PM
.Manny.'s Avatar
Touching My Member
Default Re: What wheels fit 11" Fastbrakes or Wilwood front brake kits
I asked fastbrakes a while back and was told I would need 16s. There may be 15s out there that clear. Hopefully someone on here knows because I'm interested as well.
Old Jul 14, 2010 | 08:52 PM
s10cky's Avatar
I have 15s on my wilwood setup. Just fine.
Old Jul 14, 2010 | 10:59 PM
Clipsed's Avatar
Yea I was just about to say, LS meshies cleared my 11.1" type r brakes, don't see why you couldn't find CERTAIN 15" wheels that clear the brakes.
Old Jul 15, 2010 | 08:14 AM
.Manny.'s Avatar
Touching My Member
That is what I wanted to run! But opted for the regular integra calipers because I had fresh DX knuckles with new bearings, ball joints and wheel studs installed and didnt want to source EX knuckles.
I was told the meshies would not clear the wilwood kit
Old Jul 15, 2010 | 08:48 AM
CRX Toad's Avatar
Call Fastbrakes I'm sure they know. Why ask a bunch of people that "might know".
Old Jul 15, 2010 | 09:07 AM
Clipsed's Avatar
The only reason I see it not clearing is because they are 4 pot, correct me if I am wrong.
Old Jul 15, 2010 | 09:08 AM
wheelgarage's Avatar
16's are safe, depending on offset. My cousin's DA has Wilwoods, running on 16" Wats and Sure wheels. They fit perfectly fine with +38 offset. If you would to though 15"s on there, you would have to find one that has the barrel and back face clearence...
Old Jul 15, 2010 | 10:23 AM
nickrps's Avatar
15's will work. Here's a list of wheels I've tried and run on my 11" fastbrakes kit (Corrado rotors) with Wilwood calipers. There are a ton of 15's that fit...just depends on spoke design.
FIT:
- Volk CE28, 15x7, +43 with 5mm spacer
- Team Dynamics Pro Race 1, 15x7, +40
- Motegi Track Lite, 15x7, +38
- Mugen MF10L, 15x7, +38...i think that's the offset
- Kosei K1, 15x7, +38
- Regamaster Evo, 15x6.5, +40 with 5mm spacer
Won't Fit:
- Enkei RPF1, 15x7, +38
- Rota slipstream, 15x7, +38
- Rota Grid, 15x7, +40
- Bridgestone Super R.A.P., 14x6, +38
- BBS RA, 15x6.5, +38
Old Jul 15, 2010 | 03:19 PM
The first thing I did was call Fastbrakes. The only ones he knows of is the Team Dynamics that they sell, which do not appeal to me I am looking for input from someone that has wheels with this brake setup. I was wanting to run TE37's in 15's or 16's if they will clear.
Old Jul 15, 2010 | 03:22 PM
FIT:
Won't Fit:
Thanks for the help. I am hoping someone will chime in with Volk TE 37's.
Old Jul 15, 2010 | 04:18 PM
nickrps's Avatar
A track buddy of mine ran the 11" kit with GSR calipers and his Volk TE37's fit. I'm very confident when I say the barrel will fit, but you'll need to use a spacer so the spoke will clear the wilwood caliper. My Regamasters BARELY fit. There's probably 2mm between caliper and spoke. I plan on picking up some TE37's in a +38 offset and will more than likely have to run a 5mm spacer.
Just make sure to roll your fenders and you'll be fine.
Old Jul 15, 2010 | 05:52 PM
ucc crx's Avatar
i have 15in rota circut 8's and they fit fine
Old Jul 16, 2010 | 07:57 AM
nickrps's Avatar
Yep, Circuit 8's and 10's will fit
Old Jul 21, 2010 | 01:30 PM
shift_wagovan's Avatar
Any pics to verify that they fit?
Old Oct 13, 2010 | 01:01 PM
nihkon's Avatar
That's a great list Nick! Thanks!
I'm thinking about taking advantage of the Wilwood sale, but I'm unsure if my wheels will fit over them.
I'm running:
SSR Type C 15x6.5" +40-ish
Anyone have experience with those?
Old Oct 13, 2010 | 01:41 PM
.Manny.'s Avatar
Touching My Member
I'm running:
I bought the Wilwood 11" kit, Fat Fives actually fit with no spacers at all!! Not sure what the offset is. I believe +42
So I'm guessing Meshies and Blades will work as well.
Old Oct 13, 2010 | 02:50 PM
asianflava's Avatar
Here is the Fastbrakes kit behind a set of 15in Rota Slipstreams. I'm unsure of the width and offset because I got them used. It's a tight fit, but they fit. The CRX has the factory brakes for comparison, it also has 15in wheels.
Old Oct 13, 2010 | 03:22 PM
same ol Steve's Avatar
I have the Fast Brakes kit and have run the following,
15x7 +40 Konig Rewinds with a spacer
LS web/mesh no spacer
15x6.5 +45 Enkei J Speed 3's no spacer
Old Nov 28, 2010 | 08:05 PM
3rdGenA-SPEC's Avatar
i have the fastbrake 11 inch kit on my 98 civic cx with si wheels.very tight fit.thinking about the te37 as well.any one confirm that the te37 will fit.want to stay with a 15.if i need to run a 16 in that wheel what off set do i need.
rs250nut
Mar 17, 2013 03:17 PM
vteclolz
Jul 24, 2012 03:01 PM
ChaseIntegra
Suspension & Brakes
37
May 21, 2012 06:17 PM
Malakai
Apr 4, 2012 07:41 PM
highneo
Dec 9, 2008 01:49 PM
