Garage sale, b series & crx stuff, etc.
Everything is best offer. I'm trying to get this stuff out of the garage, and I feel bad throwing a lot of it away. I'm not trying to get rich... but remember that I am really lazy. This means you will need to offer enough $$ to cover shipping and to convice me to go to the effort to ship the item to you. Some items I'll give you for free if you buy another actual item...
'95 LS longblock. ~70k miles. Missing some dumb stuff like the plastic covers and crank pulley, etc. If you really want me to part out the block and head I might.. convince me. This bad boy is pick up only in Sacramento, CA. Sold.
http://imglib.************/index.cgi?...wimage&id=5029
http://imglib.************/index.cgi?...wimage&id=5030
http://imglib.************/index.cgi?...wimage&id=5031
http://imglib.************/index.cgi?...wimage&id=5032
Light Flywheel for D16/ZC. Everyone tells me that they don't know which car this came off of... But it weighs 11lbs. It is an OEM flywheel and has not been lightened from the factory, it is cast. Much lighter than stock D16A6 flywheel and obviously thinner.. see pictures: Pending
http://imglib.************/index.cgi?...wimage&id=5023
http://imglib.************/index.cgi?...wimage&id=5024
Aeroquip -6AN stainless line. ~15 feet. Good stuff I Just don't need it. There is some extra earls line in there too, so it probably totals near 20 feet. Sold.
http://imglib.************/index.cgi?...wimage&id=4989
Bare '98 LS intake manifold.
http://imglib.************/index.cgi?...wimage&id=4990
88-89 CRX Si clear corners. Brand new.
http://imglib.************/index.cgi?...wimage&id=4991
94-01 Integra GSR indiglo gauges. Mad tite yo:
http://imglib.************/index.cgi?...wimage&id=4992
94-01 Stock interior door handle covers with power lock switches
http://imglib.************/index.cgi?...wimage&id=4993
Two B18B oil pans. One has a tube welded onto it for an oil return. Unwelded pan is pending sale.
http://imglib.************/index.cgi?...wimage&id=4994
http://imglib.************/index.cgi?...wimage&id=4995
HCP adjustable shift linkage for B series swap into 88-91 crx. Missing the tranny side piece of the stabilizer bar. Linkage bar is complete.
http://imglib.************/index.cgi?...wimage&id=4996
Two sets of B18B1 cams w/ cam gears
http://imglib.************/index.cgi?...wimage&id=4997
Cheap automotive spray gun set, brand new. Includes base gun and a detail gun. Bought this at lowes and never used it.
http://imglib.************/index.cgi?...wimage&id=4998
LS valves, springs, retainers, rocker arms, etc. Lots of them. If you want some now is the chance before I throw them away.
http://imglib.************/index.cgi?...wimage&id=4999
'97 LS pistons and rods. ~40k miles. They look dirty because they are but they are in perfect shape.
http://imglib.************/index.cgi?...wimage&id=5000
Two 90-91 Integra throttle bodies. One is sold.
'97 Integra LS oil pump, ~40k miles.
'94 Integra LS water pump, under 10k miles.
1st gen B16A hard coolant line w/ thermostat housing Sold.
http://imglib.************/index.cgi?...wimage&id=5001
'94 Integra LS crank pulley, comes with a free chip taken out of the outer edge. Sold.
'88 CRX Si Alternator
'94 Integra LS Alternator
Breather canister from the back of a 90-91 Integra B18A
http://imglib.************/index.cgi?...wimage&id=5002
(1) Horn
88-89 CRX OEM Corner lights Sold.
88 CRX Rear wiper motor
B series tranny reverse switch
http://imglib.************/index.cgi?...wimage&id=5003
94-97 Integra bra. Came with my Integra when I bought it in 1999. I've never used it, but I'm sure the previous owner did.
http://imglib.************/index.cgi?...wimage&id=5004
ACT solid hub 6 puck clutch disc for 90-91 Integra. Used for ~10k miles. Lots of life yet.
Stock '94 Integra LS clutch disc.
http://imglib.************/index.cgi?...wimage&id=5005
http://imglib.************/index.cgi?...wimage&id=5006
http://imglib.************/index.cgi?...wimage&id=5007
88 CRX Si defroster switch
88 CRX Si dimmer switch
OKI igniter from 88 CRX si distributor, but fits everything
88 CRX Si idle air control valve
http://imglib.************/index.cgi?...wimage&id=5008
Straight pipe. Came from an '88 CRX. Looks like a cat, but it sure isn't. I've actually thought the car had a cat all along until I took the"Cat" off.
http://imglib.************/index.cgi?...wimage&id=5009
http://imglib.************/index.cgi?...wimage&id=5010
Change holder thingie from 88 CRX Si dashboard
http://imglib.************/index.cgi?...wimage&id=5011
88 CRX Si starter
B series tranny cable VSS.
http://imglib.************/index.cgi?...wimage&id=5012
Energy Suspension Torque Mount inserts for 94-01 integra. Missing the rear mount, but who actually installs that thing?
http://imglib.************/index.cgi?...wimage&id=5013
HCP front engine mount for B series swap in 88-91 CRX/civic.
http://imglib.************/index.cgi?...wimage&id=5014
Momo Combat shift ****, red. Perfect condition. Sold.
http://imglib.************/index.cgi?...wimage&id=5015
Tenzo short shifter for 94-01 Integra. Fits other cars. 3 little knicks at the top where I attached the above Momo shift ****.
http://imglib.************/index.cgi?...wimage&id=5016
Mad tite chrome looking shift ****. This thing has to go.
http://imglib.************/index.cgi?...wimage&id=5017
Two 88 CRX MAP sensor/Purge control solenoid assemblies.
http://imglib.************/index.cgi?...wimage&id=5018
94-01 Integra LS alternator belt (Honda Part)
88-91 CRX Alternator belt (from auto parts store).
Both are brand new. I feel bad throwing them away. They are free if anyone wants them.
http://imglib.************/index.cgi?...wimage&id=5019
Earls fittings, misc. Maybe you need one of these parts? I dunno. Sold.
http://imglib.************/index.cgi?...wimage&id=5020
'95 GSR fuel pump
88-91 CRX/Civic Hood Hinges
1st Gen B16 injectors (non obd, low impedence)
88 CRX Si A/C switch
http://imglib.************/index.cgi?...wimage&id=5021
Red Sparco Hood Pins. Brand new. Sold.
http://imglib.************/index.cgi?...wimage&id=5022
Black 88 CRX Si center console. Previous owner tried mounting something to the side of it so there are a few holes.
http://imglib.************/index.cgi?...wimage&id=5025
http://imglib.************/index.cgi?...wimage&id=5026
"Black" 88 CRX Si carpet. Pretty good condition, look at the picture. Sold.
http://imglib.************/index.cgi?...wimage&id=5027
'88 CRX Si clutch cable. Very good condition.
http://imglib.************/index.cgi?...wimage&id=5028
Magnecor Spark plug wires for 94+ Integra GSR. Under 10k miles.
I'd be lying if I told you I liked Magnecor spark plug wires, that's why I am selling them. But maybe you like them so buy them thanks.
http://imglib.************/index.cgi?...wimage&id=5033
(1) Horn
88 CRX Si starter
'95 GSR fuel pump
Where are you located? how much you want for the B series VSS? Im located in los angeles, let me know.
ADuong123@aol.com
ADuong123@aol.com
is that a hole in the side of the crx carpet?
The hole at the far right is where the passenger seatbelt bolts to the frame
ADuong123@aol.com
ADuong123@aol.com
How much for the Aeroquip -6AN stainless line and extra earls lines and fittings. Don't wanna low ball.
I dunno about the fittings, whatever.. hehe
do you have any references ?
hehehehehhe
Dustin, what sizes are those fititngs ?
stan
hehehehehheDustin, what sizes are those fititngs ?
stan
(2) -6 AN plugs
(1) straight -6 AN hose end
(1) straight -4 AN hose end
-4 AN to -6 AN reducer
1/8" NPT to 1/4" NPT reducer
Im still interested in the B series VSS. 10 shipped? im in los angeles. let me know
aduong123@aol.com
aduong123@aol.com
aduong123@aol.com
aduong123@aol.com
Do you still have the Cable VSS, The Stainless line and the Earl's fittings ?? if so how does 75 Shipped for everything sound???
. im in sac. also how much on the ls longblock. or shortblock if you'll sell it.
im interested in the 6 puck disc to you have the trhowout bearin and pressure plate and how much????
what are you asking for this setup Dustin?
shipped to so cal 91977
I could use that CRX Alternator belt. I live in South Sac/Pocket/Greenhaven Area
Email me when I could pick it up. SactownXSi@yahoo.com
-Nick
-Nick
Damn the ss lines are sold? Arrgggggg!!!
I'm actually in folsom. I think I paid like $10 for the belt so I dunno if you want to drive all the way up here for it, but if so you can have it.
