USDM vs JDM
Are the JDM and USDM ITR rear sway bars the same size? I need to order the clamps the go over the bushings for my JDM sway bar and I was going to order the USDM ones from Acura since I don't know where to get JDM ones . . . .
brackets will work on either but if you cant find oem 23mm bushings
97 prelude base used a 23mm rear sway so can use bushing from that from honda
ES makes some
http://www.amazon.com/Energy-Suspens...ing/dp/B000MW8
copy n paste this link
http://www.prothanesuspensionparts.c...hane&Sec=10572
ES makes some
ES makes some
ES makes some
