14" rims fit over gsr brakes?
hx wont fit on a 98 ls dont know about the gsr but they are the same brake system so NO it will not fit. the fronts wont fit but the rears fit. if you wanna make the fronts fit you have to get a adapter/spacer thing. but dont recommend useing the spacer adapter bs.
i've researched about hx rims on tegs on this site as i want to use them too and from what i've read is that u can use spacers or just shave a little on your brake calipers.
gsr brakes = ls/rs/gs brakes
Nope. The RS brakes are different.
put a couple of washers on tha lug studs on tha front and tha HX's will fit...i have done this on my gsr and it worked...dont need any washers for tha back........
ok....if I can run 13s on my RS, and I know personally of three different guys running 13s on GSR's you shouldn't have a problem running 14s. Hell, RS's come with 14s. and I'd like to know how GSR brakes are different from RS brakes......b/c I'm pretty sure that they aren't, though I could be wrong
from what i hear.....gsr and 00 si has the same size breaks and my friend tried fitting the hx rims on his si, didnt work. So i'm assuming they wont fit....but then, my friends 4dr gsr got jacked and they left him 2 hx wheels...so i basically i'm no help...sorry
It all depends on the offset and design of the wheel.
I know a guy running 13x8 Lenso VPD's on his GSR with no spacers. but the wheel weights have to be put some where where the calipers wont knock them off
His name on Honda Tech is Geratol.
The reason a 14" Steelie fits a gsr and a 14 HX doesnt is because of the wheel design. The inside part of the spokes on the HX hit the caliper, hence the spacer.
ALL 94-01 NON Type R integras have the same size ROTORS for sure. Not sure about the calipers though, but I am pretty sure they are all the same too. These are also the exact same brakes on the 99-00 SI.
His name on Honda Tech is Geratol.The reason a 14" Steelie fits a gsr and a 14 HX doesnt is because of the wheel design. The inside part of the spokes on the HX hit the caliper, hence the spacer.
