g motor q
Old Jul 14, 2010 | 02:23 PM
h22carpetride's Avatar
Default g motor q
got a f22b, out of a 95 exr, got a h22a head that will sit on it. now honda stated cylinders can be bored to 86mm's max, i know k20 pistons generally are 86mm's, seeing as how this is an open sleeve block, am i risking damage by dropping in forged pistons after a 1mm overbore? i havent taken anything apart other then the head so i can measure cylinder bore.
can i use my h22 crank with f22 rods with this motor? are the main's the same size? not too much info out there on this build
i want to put k20 wiseco pistons but am unsure if it will work, because most of the g builds are with h23/f23 combo.
any help is appreciated guys thank you, will be a h2b dropped into a eg hatch
Old Jul 15, 2010 | 12:17 AM
kingofbattle909's Avatar
Default Re: g motor q
http://zealautowerks.com/hfseries.html
Old Jul 16, 2010 | 09:13 PM
saved, will help alot during the build. thank you
95accord3267
Aug 22, 2014 01:10 PM
REDLUDE4WS
Feb 21, 2011 12:25 PM
h22carpetride
Mar 25, 2010 09:02 PM
msp2003.5_nick
24
Mar 14, 2009 10:21 PM
SP GARAGE
Nov 4, 2007 08:04 PM
