99 SI Weird Idle Problem.
Hey guys, I have the weirdest problem I have ever seen on civic. A little brief history on the car. Got it as a theft recover with a missing head. Slapped on a pr3 head I had from my previous car with a obdI style intake manifold. It drives and shifts good, but it idles at 1500 rpm no matter want, and it fluctuates from 1k to 2k especially when coming out of gear. I have cleaned the fast idle thermo valve, and idle control valve numerous times and it still persists. I have even replaced the throttle body and idle control valve and still no go.
Here's a sample of whats happening.
http://s153.photobucket.com/albums/s...t=MVI_2441.flv
Engine Bay:
Engine Bay:
All vacuum hoses are connected, even to the charcoal box. The intake manifold is torqued down to specs with a new gasket. (I don't there is a vacuum leak, but you never know.) The cooling system was bled, (ran without the cap in till the fan kicked in.) The car has been sitting for a while and only today I took it for a test drive and so far the CEL didn't kick in. It did through a code awhile ago, but I forgot it.
When the engine is warm, pull off the intake and cover the port leading to the FITV inside the throttle body with your finger. Does this lower the idle speed and stop the surging? Do the same test on the port leading to the IACV.
My initial thought was vacuum leak, But then I remembered when I was having this problem with my LS/V and I found the problem in the engine harness.
My idle surge was more erratic than your's but doing continuity check from the ECU side of the harness to the IACV plug in the engine bay would definitely not hurt to rule out wiring as the issue. You can find the pin out diagram for your vehicled harness all over this site and Google.
But I think first and fore most like Ron said, Figure out what CEL codes your throwing and then post em up. That will at least get you out of the guessing game and onto to finding the real problem.
Just came from 20 min or so test drive and sadly the CEL didn't come on yet. As far as the test goes, with the car warmed up, covering the lower hole which I think is the FITV had no impact on the idle. Covering the upper hole on the other hand dropped the idle down where its supposed to be at around 700rpm. So what does that mean?
Does the CEL work? If there are no codes, the CEL should turn on and then off after 2 seconds when the key is turned to ON(II).
Sounds like an IACV problem. What happens to the idle speed if you unplug the IACV connector? Have you tried adjusting the idles speed to spec with the idle screw on the throttle body? Have you tested the ECT and TPS sensors?
Yes, the CEL does work, it just the sensor didn't tip it off yet. Yes I did adjust the idle through the screw on the throttle body, but it didn't help with anything. I am going to see what unplugging the IACV does. Also how would I test the tps and ect sensors? see if there is voltage going through the wires?
Update: Disconnecting the IACV caused only caused the CEL to come on, no idle changes. Plugging it back in though, caused the idle to fluctuate between 1600 and 1700.
Measure the resistance of the ECT sensor when the engine is fully warmed up.
Measure the output voltages of the TPS at closed and wide open throttle.
Test the ECT and TPS.
Ok done checking and got .3 ohms on the ECT with the engine hot and off. I couldn't get any readings of the TPS. Tired with the ignition on, and pin 1 and 3 on the tps. couldn't get any voltage to show. ac and dc. Also found the autozone printout of the CEL. It was code P0505.
Ok, the TPS is as follows: .28 closed and 4.28 with full throttle.
Going back to the coolant question. I was wondering if having a t stlye hose to distribute the coolant to the FITV, IACV and throttle body could be problem. I attached a image of how the t hose looks like.
its going to be the IACV, cuz the way he explains it...i had the same problem with my hatch and i remember putting a cig butt for a week straight just to keep the idle right. ghetto but don't try it haha just replace it kid. thats why i had my share's with honda's and went to something else lol
I am in the process of stealing the IACV from my brothers integra. going to swap it over and check it out. And Ron, I think it was .3k ohms. I'll double check that.
yea i knew it wouldn't work cuz your bro's a teggy...a new one is mostly like $165 bucks at autozone. if you buy a used one later down the road it'll do it all over again. might aswell just spend the money and be happy
In contrast, coolant hoses to the FITV are important for it to work correctly, though the FITV does not seem to be the problem.
Hi, I am from Costa Rica.
Double check your idle control valve becuase is a very common problem in some honda engines. You may have cleaned the idle control valve, but are you sure is working? With a damage idle control valve the ecu do not show any codes in most Honda. If you have any other damage sensor or a vaccum leak the idle is not steady. If you have a steady but high idle be sure the idle control valve is okay.
I know you have a Si, but this is a very common problem in the 1997-2000 DX and Lx Civics.
The Tps do not do much in this model, it is like a reference to the ecu. Almost everything is base on the Map sensor and Crank sensor, its a Motronic base fuel inyection, not a J-tronic. In old model cars ( European and Japanese ) Tps rules almost everything.
Problems like vaccum leaks, Map, rich mix, stuck open fuel inyectior, fuel pressure regulator to not increase idle that much. How is fuel consumption?
Check the throat body for vaccum leaks at the leverage, I have seen some similar problems with a very old or modify throat body ( overbore )
Also check the gas cable free play
Update:
Alright guys, I stole another IACV from a buddy who's rebuilding his engine, and after slapping that thing on, and adjusting the idle via the screw on the throttle body, what can i say, IT WORKS!! It idles smoothly at 750 or so rpms. I still need to go buy one myself, and take it on the road for a test drive. As I said in my first post, I swapped over another throttle body and IACV and the problem persisted. That's why I was thinking it was not the IACV. Anyway if you guys find yourself lost in Charlotte, hit me up, I'll reward with a drink or something. :D
