What car should I get steering knuckles from for front brake upgrade?
Old Jul 14, 2010 | 08:31 AM
fryman's Avatar
Icon2 What car should I get steering knuckles from for front brake upgrade?
I'm going to do a upgrade to bigger disks for my front brakes so I just want to know which car I should get the steering knuckles from.
My car is a eg civic sedan non ABS with 15" gsr fat fives.
I was thinking I could get the gsr steering knuckles but I think they're ABS so I'm guessing they wouldn't work?
Old Jul 14, 2010 | 08:58 AM
EL Vap133's Avatar
Default Re: What car should I get steering knuckles from for front brake upgrade?
They will work, all the ABS thing is are some wires and that should be it. Just take them off the brake assemblies and they will work the same. You can use any 94-01 Integra front brakes.
Old Jul 14, 2010 | 09:15 AM
fryman's Avatar
Ok thanks
Old Jul 14, 2010 | 11:01 AM
fryman's Avatar
I forgot to ask,does it matter which body style the knuckle comes from(4dr,2dr,hatch)?
Old Jul 14, 2010 | 11:34 AM
civicsmoke's Avatar
no it doesnt matter. get them from a integra 94-01
Old Oct 23, 2011 | 12:43 AM
fryman's Avatar
Are all 94-01 Integra front disk brakes the same size on all models? I just want to make sure because I want the best stopping power I can get.
Old Oct 23, 2011 | 01:48 AM
B16B Four Door's Avatar
If you want even better stopping power you can use your stock knuckles and get the fastbrakes 11" rotor kit then you just use the integra calipers.
Old Oct 23, 2011 | 05:42 AM
94EG8's Avatar
Seagull Management
ITR brakes are larger, but then you need to convert to 5 lug.
Old Oct 23, 2011 | 09:26 AM
fryman's Avatar
So all Integra rotors are bigger than my Civic DX sedan ones right? And you're saying all models of Integras, that are 4 lug, all have the same size rotors? Is it even worth it to upgrade and would I notice a difference?
Old Oct 23, 2011 | 09:38 AM
Wrona's Avatar
yes all 94-01 integra Front knuckles are thesame and so are the rear EXCEPT THE INTEGRA TYPE R like 5 people already said this
Old Oct 23, 2011 | 09:56 AM
Hidenplanvew's Avatar
notice over what? are you doing 150mph in your dx? just get integra ffronts and you can stop a bullet
Old Oct 23, 2011 | 06:56 PM
NotAJDMFanBoy's Avatar
I think it was 94 and up EX and all Si (someone please correct me if I'm wrong) have the same size rotor as an Integra. I know the pads for the Civic EX are different than the Integra, or maybe the Integra with ABS. It depends what caliper bracket you have.
Some people redrill the Prelude/Accord Wagon? rotor, which is supposed to be the same size as the ITR. Then using the drilled rotor, a DX knuckle and a modified caliper bracket and some caliper you can get like 11" brakes.
Integra brakes should be plenty especially if you bleed them well and have good rotors and pads.
Old Oct 23, 2011 | 08:06 PM
ex/si ar not the same size as tegs
Old Oct 23, 2011 | 08:44 PM
Wrona's Avatar
the 96-00 EX/Si had thesame brakes on the front as the integra the si has same rear brakes the EX has drums
Old Oct 23, 2011 | 08:48 PM
98civdx's Avatar
Master Detailer
Really the only thing different with the integra is the fact the pistons are a little bigger (non-ITR) then civic's.
However if you do end up going with integra front brakes, you should be runing a DC mater cylnder.
Old Oct 24, 2011 | 06:07 AM
kyden's Avatar
integra and civic ex/si calipers are not the same. they are the same size rotor, but the pads are thicker on integras, therefore use a wider caliper.
MumBleZ_94gsR
Nov 25, 2009 07:42 AM
dynimitejack
11
Aug 9, 2008 11:32 AM
blkgsr03
Aug 23, 2004 12:05 PM
sleeping beauty
Apr 7, 2004 05:13 PM
youngkow
Nov 14, 2002 06:16 PM
