HOW DO I REMOVE THE INSTRUMENT PANEL TO REPLACE A BULB FOR A 00 ACCORD EX?
TRYING TO SAVE A FEW BUCKS HERE...DEALER WANTS 147 BUCKS TO CHANGE IT FOR ME. I JUST WANT TO DO IT MYSELF, ANY SUGGESTIONS ON HOW TO REMOVE IT? IM HEARING ITS PRETTY TOUGH TO DO...
-you unscrew the screws at the top of the culster bezel
-you have to pull back on that bezel so that the two clips at the bottom of the actual gauge cluster will unclip (theyre the pain in the *** part)
-then you unscrew the screws at the top of the cluster piece (theyre like the bezel screws at the top) and you also unscrew the screws at the bottom of the cluster
-you pull it foward a little, and then you try to rotate it with the gauge faces pointing down
-then push it back a little and then you can unclip the clips at the top of the cluster
-after its all unclipped, you can pull it out and change out the bulbs on the back. the bigger black sockets (i guess you could call them that) are the ones that light up the faces and the needles. theirs 2 small ones for the temp gauge.
Jakemmarsh
May 15, 2012 05:26 PM
honda_2003
Nov 5, 2008 06:39 PM
septemberfreedom
Jun 3, 2005 05:23 PM
