Axle binding or rubbing somewhere what to do?
ok so whenever i cut my wheel left or right the whole way my axle rubs on i think my shock fork (not sure of name) or binds up somewhere any way i could fix this or if you anymore questions about anything.
the car is a 90 civic with b16a swap and ef9 axles
ground control and koni suspension setup
thanks alot in advanced!
i have a feeling its rubbing on the fork that connects my strut to my front lower control arm and i know its not the tire due to no damage on either tire and they have 2-3inches of clearance on the sides.
Just because you have a feeling doesn't mean that is the problem. You say your tires have 2 inches of clearance...that's at ride height. How much clearance do you have when the suspension is compressed? Instead of paint, use chalk to mark different areas. It'll transfer much easier than paint.
Peteypablo17
Transmission & Drivetrain
Feb 10, 2013 05:31 PM
shorty0o29
Feb 24, 2004 09:31 PM
