is my head real???
Old Sep 15, 2002 | 02:26 PM
baonest's Avatar
Default is my head real???
ok well i was looking in the helms manual for the bolts for the head. i look and the B18c5 head has all the studs for nuts, and the b18c1 head doesnt. just 2 studs for nuts. this is my head it has PR3-4 written on the side. is this a GSR or Type R. dont tell me ever since i been thinking its been a TYPE R. it had the green paint of whatever on that tab too.
whats goin on?
[Modified by baonest, 6:26 PM 9/15/2002]
Old Sep 15, 2002 | 02:30 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: is my head real??? (baonest)
huh? my gsr head has all studs. yours doesn't.
Old Sep 15, 2002 | 02:31 PM
baonest's Avatar
Default Re: is my head real??? (SkyeC)
i was told it was a ITR... does yours say PR3-4 on the header side?
Old Sep 15, 2002 | 02:34 PM
HybridHatchC1's Avatar
my 2001 gsr has only 2 studs
Old Sep 15, 2002 | 02:36 PM
baonest's Avatar
Default Re: is my head real??? (Civ-JDM)
the head is a '00.
Old Sep 15, 2002 | 02:37 PM
baonest's Avatar
Phuckin ***.... i swear if this is a GSR head im comin after that damn seller and beatin the living ***** outa him. im really pissed right now.
Old Sep 15, 2002 | 02:38 PM
spoon_ek9's Avatar
look thought the top of the head, it should be a "30" on it. gsr is 72.
Old Sep 15, 2002 | 02:42 PM
baonest's Avatar
Default Re: is my head real??? (spoon_ek9)
ok, im gettin a bit happier, but whats up with the studs.. why is there only two of them. could i use bolts??
Old Sep 15, 2002 | 03:03 PM
slowerthanu's Avatar
New User
My Type-R head uses 2 studs and the rest are bolts.
Old Sep 15, 2002 | 03:05 PM
baonest's Avatar
Default Re: is my head real??? (slowerthanu)
hmm what size are the bolts... im sure they are same size as other head bolts.
Old Sep 15, 2002 | 03:18 PM
TurboDANDEE's Avatar
when Honda switched to OBDII from OBDI.. they changed the studs on the head. The older GSR 94-95 used studs and the newer version 96-00 GSR, 98+ Type R, 99-00 Si uses the bolts and 2 studs at the end. The type R/Si head has a stamped P30 on it. If u cant tell from a GSR head and Type R head, then u got problems. they have different combustion chambers and intake manifolds have different bolt patterns so they wont fit if u try to put a GSR on a type R head and the other way around.
Old Sep 15, 2002 | 03:43 PM
Tommy_Gunns's Avatar
Calm down, I have only 2 studs as well.
My ITR head says PR3-2 I think (haven't looked in a while).
[Modified by Tommy_Gunns, 6:44 PM 9/15/2002]
Old Sep 15, 2002 | 03:50 PM
spoon_ek9's Avatar
Default Re: is my head real??? (Tommy_Gunns)
yea, calm down man. ppl usually take out the stud when they work on porting job.
Old Sep 15, 2002 | 04:10 PM
baonest's Avatar
its been 2 studs when i bought it... man that helms manual got me shook.
Old Sep 15, 2002 | 05:15 PM
hybridDC4's Avatar
ye u can easily back the studs out or put em in...ive had 2 of em come out on me when breaking them loose...ur ok man u still got a type r head
Old Sep 15, 2002 | 05:22 PM
Tbone's Avatar
Ok , look at the shape of your combustion chamber, Gsr heads are not round and look like this.
Except this is actually a r head with welded combustion chambers to mock a gsr head.
Take some more pics of the port work though , I would like to see.
[Modified by Tbone, 9:23 PM 9/15/2002]
Old Sep 15, 2002 | 05:31 PM
ITR#132's Avatar
ITR head and GSR head is totally different. (What you should be worried is if it is a Civic Si/Del Sol VTEC head)
But since you think it is a GSR head; What Intake Manifold are you using? Where is the Water Outlet Spout located (under the VTEC solenoid or undert the Distributor)? Like mentioned already; How does the combustion chamber look like? Check the Intake Valves.
Old Sep 15, 2002 | 05:42 PM
jsk62's Avatar
u can relax. PR3-X stands for a B16 head, which is wat type R's use. my type R says PR3-3, but the second # doesn't matter. u have a type R head, don't worry about it.
baonest's Avatar
Default Re: is my head real??? (ITR#132)
im using the intake mani. from a ITR... it bolts up fine.
Old Sep 15, 2002 | 06:28 PM
Tbone's Avatar
Even more proof for you , this is my 2000 type r head pr3-4. that should put the nail in the coffin for ya.
Old Sep 15, 2002 | 06:42 PM
GokuSSJ4's Avatar
Default Re: is my head real??? (Tbone)
theres a difference on the combustion chambers from a b18c1 head an a b16a/b18c5 (the b18c1 looks like it has on the chamber to pieces of metal blocking part of the chamber , and thats how a gsr head gives you more CR )
check it out
baonest's Avatar
thanx tbone... now im convinced. but my Q is still about the studs, i can get 6-7 from acura carland and put them in, or should i get some bolts that will fit the holes.
Old Sep 15, 2002 | 06:46 PM
AssPenny's Avatar
My head only has 2 studs
Old Sep 15, 2002 | 07:24 PM
EPGONZALEZ's Avatar
Default Re: is my head real??? (AssPenny)
chill about the head studs...like they said before...they are removable
Old Sep 15, 2002 | 08:04 PM
baonest's Avatar
Default Re: is my head real??? (C5_ALLMOTOR)
if you use bolts and not studes with nuts, you need to have the right ones, i accidentally mixed one of mine up and it was just a hair too long and it broke off, so make sire you get the proper bolts
i hear that. when putting in the studs, all they do is screw in. do i need to put some sorta like locking glue or whatever its called on them?
