confused ??
Old Jul 13, 2010 | 05:44 PM
miguey310's Avatar
Default confused ??
well now my car is choking and all that and i don't know what it is , when you step on the gas it sounds like it's below the rev lim and it sounds like it gonna turn off but doesn't , i changed the fuel filter and when i filled up the gas tank it didn't really happen but it about 1/4 and it startin to do it again , and it's giving me code 17
Old Jul 13, 2010 | 06:07 PM
miguey310's Avatar
Default Re: confused ??
gave me code 17
Old Jul 13, 2010 | 06:10 PM
BiG ChOr!Zo's Avatar
vss wouldn't cause those problems
Old Jul 13, 2010 | 06:14 PM
miguey310's Avatar
i know , that's why i'm confused
Old Jul 13, 2010 | 08:50 PM
StayKrafty's Avatar
Fuel pump maybe?
Old Jul 13, 2010 | 09:09 PM
miguey310's Avatar
Originally Posted by mybikeisblack
Fuel pump maybe?
could it ?
Old Jul 13, 2010 | 09:15 PM
StayKrafty's Avatar
Well, you say it happens when the tank is at 1/4th right? I had a hard time trying to understand your first post. Basically, you're saying that the car is hesitating when you give it gas?
Old Jul 13, 2010 | 09:19 PM
miguey310's Avatar
well this recently happen so pretty much yeah, naw only on low RPM
Old Jul 13, 2010 | 09:20 PM
StayKrafty's Avatar
How far can you rev the engine, like what RPM does it happen at/
Old Jul 13, 2010 | 09:23 PM
miguey310's Avatar
you can drive it normal but on the low Rpm like 1000-3000 it happens
Old Jul 13, 2010 | 09:30 PM
StayKrafty's Avatar
Hmm, do a compression test. Something like this happened to my integra and not too long after that my head gasket blew. Cause mine would hesitate, sputter and want to die if i mashed the gas but once it hit 4000ish RPM it drove fine. Those are just my two guesses at what it could be. Good luck though, wish I could be more help.
Old Jul 13, 2010 | 09:38 PM
miguey310's Avatar
even with a full tank ?
Old Jul 13, 2010 | 09:40 PM
StayKrafty's Avatar
Fuel pump can go bad no matter how much is in the tank yes.
Old Jul 13, 2010 | 09:45 PM
miguey310's Avatar
but why does it only happen when it's nearly empty ? and it seems like it under reved when it acts up
Old Jul 14, 2010 | 07:14 AM
Clipsed's Avatar
love how you say I haven't checked the codes, then check them, then chorizo tells you code 17 wouldn't give you that issue, and your response is, that's why I'm confused... lolz you are HT's biggest idiot lmfao.
Old Jul 14, 2010 | 07:46 AM
4g4dcruisin's Avatar
He did check the codes haha!
You could have faulty injectors also. Its more than likely fuel related.
Old Jul 14, 2010 | 08:49 AM
Clipsed's Avatar
Well he either is really just stupid, or just doesn't know how to write, because what I gather from his first post where he says, "and i have checked what codes it readin ,been to busy." He meant to say, I HAVE NOT checked what codes because he was to busy, then about 30 minutes later comes back and posts the code 17...
Also, buy a new car, maybe a Toyota, you fail at Honda's and HT as well.
Old Jul 14, 2010 | 09:04 AM
Me? haha.
Old Jul 14, 2010 | 09:11 AM
Clipsed's Avatar
lolz, no this kid man, he cracks me up every time he posts. I wish he still had the gay avatar of himself, made me crack up every time I saw that ****!
Old Jul 14, 2010 | 09:15 AM
haha alright cool.
Oh i found out my throttle cable is frayed...right in the grommet where it enters the firewall. So when it gets pulled by the pedal, the fray is pointing toward the engine bay, so it gets stuck by the wires frayed off it.
Half off day at the San Bernardion Pick-a-Part this Sat. the 17th.
Old Jul 14, 2010 | 11:24 AM
Clipsed's Avatar
cool beans. Hmm a lil too far for me, and I'm broke...
Old Jul 14, 2010 | 11:33 AM
TJChad's Avatar
I'm not saying it's your problem but if you have a code fix the code!! You don't know what the computer uses for what calculations, but it only happens at 1/4 tank? Are you sure your gas gauge is reading accurately?
Old Jul 14, 2010 | 03:00 PM
miguey310's Avatar
haha i check after the post haha :p
Old Jul 14, 2010 | 03:02 PM
miguey310's Avatar
well you like talking **** haha
Leander003
Honda Civic (2001 - 2005)
Oct 26, 2018 09:16 AM
ALLDAY-24
Oct 5, 2011 04:12 PM
Fat Chick Magnet
Oct 6, 2008 10:28 PM
Flatland2D
Jul 28, 2007 10:37 AM
GsrTurboCRX88
Oct 22, 2006 10:29 AM
