help with 91 lx seat belts
Old Jul 13, 2010 | 02:05 PM
accordin 2 me's Avatar
Default help with 91 lx seat belts
ok so at first they worked rarely because the battery terminal going to 12v was bad. i swapped that out the terminal with another one making sure to fuse the 2 wires that control the seatbelts under the hood that went to the 12v on the battery.
PROBLEM:
my driver sside seat belt works fine. the passenger side went down and never came back up. WTF???? if i muscle the belt up to secure a passenger, as soon as the door opens it goes right back down and stays that way.
Old Jul 13, 2010 | 02:15 PM
lunalink's Avatar
Default Re: help with 91 lx seat belts
are you still using the fuses? i want to find out the solution because i want to get rid of that horrible terminal as well LOL.
Post pics of how you "fused" the wires..
Old Jul 13, 2010 | 02:19 PM
BiG ChOr!Zo's Avatar
i have the same problem only that its on my driverside...simple solution was to lock them back manually and disconnect the green plug on the black box located behind the stereo...!!!
Old Jul 13, 2010 | 02:21 PM
lunalink's Avatar
i still want mine to function " factory" just without that ugly azz terminal
Old Jul 13, 2010 | 02:26 PM
taking pics now
Old Jul 13, 2010 | 02:27 PM
lunalink's Avatar
Originally Posted by accordin 2 me
taking pics now
LOL. awesome
Old Jul 13, 2010 | 02:29 PM
4g4dcruisin's Avatar
On my old sedan, i just connected the auto belt wires directly to the pos terminal to the pos battery cable.
I also made sure the plug underneath each seat is plugged into the seatbelt drum.
Then there is the green plug behind the center console near the firewall.
There is no fuse or relay for the seatbelts, except for the components i just named.
Old Jul 13, 2010 | 02:31 PM
my seats don't even have them connectors unlike my old ones
Old Jul 13, 2010 | 02:32 PM
Old Jul 13, 2010 | 02:34 PM
lunalink's Avatar
Ha HA that looks funny..
Old Jul 13, 2010 | 02:36 PM
well i did alarms for a living for about 9-10 years of my life so this is the cheapest way thats effective to add an in line fuse, i just used what i had in my tool box
Old Jul 13, 2010 | 02:41 PM
lunalink's Avatar
i'm not bashing on it, are you sure you wired up everything up correctly?
Old Jul 13, 2010 | 02:45 PM
yea my voltage meter was getting 12v to the factory wIRING (DAughter) but yea everything was right i guess whats next is taking apart the factory one to see if there was a resistor inside it somewhere or a diode.
droopy128
Jan 20, 2016 11:06 PM
Phoenix007EF
Feb 26, 2010 10:07 PM
91_scca_prelude
Feb 26, 2009 11:10 AM
Vagabund07
Jun 17, 2007 08:46 AM
egsleepercivic
Oct 17, 2004 11:03 AM
