5 point harness install?
ok, i have an odd question.
i have a set of EF hatch (90 or 91) seats in a jeep wrangler. i have "5" point harnesses in it now. but am only running 4 of them.
has anyone on here put the 5 point through the factory EF seats? (anti-submarine belt)
if anyone has can you post a picture? i'm trying to not just cut a slit in the cover and slide the belt through but to clean it up a bit so it won't shred as i use the seat.
thanks in advance.
thanks in advance.
You are going to have to cut a hole in the seat pan, first of all.. not terribly hard, but i would suggest to do it right that you remove all the "hog rings" and take the foam out so it doesnt catch on fire, and then mark the spot on the seat fabric and take it to a alterations shop and have them do whatever they do to finish edges in an industrial style application. It would probably cost you no more than $20/seat, and will look good.
Have you ever used a 5 point harness on the trail before? I found it a huge pain in the *** since you are getting in and out of the Jeep constantly. Also a majority of my controls had to be moved within reach due to the fact of not being able to reach them while strapped in.
Chris F
14
Oct 16, 2004 07:50 AM
FormulaIntegra
24
Jul 28, 2004 05:14 AM
