witch dc headers do i buy for my zc
Yeah, get headers for the CRX Si. Port matching them isn't that big of a pain. Just line up the gasket with the bolt holes, mark the area needs to be ground down, and grind it down. It should take like 10 minutes
actually the best header set up would be and 89 teg dc upper with an 88-91 ef dc
lower. the 89 dc teg header is shifted to the side to match the ex ports. now see if you could find the separate.
Which witch is which?
I wish mine took 10 minutes, it took me about 20 minutes a port and I went through about 5 bits on the dremel. Does I finished with some 220 sand paper, does it need to be any finer than that? Is there really a benefit from "polishing" it after?
jedubz
Mar 1, 2004 12:43 AM
ScottEK
Sep 8, 2002 10:33 PM
