94 Accord - Fuel pump?
Old Jul 11, 2010 | 03:53 PM
sobey's Avatar
Default 94 Accord - Fuel pump?
Hi,
94 Accord I4, approx. 160k miles (270k kms). plugs/wires/cap/rotor/timing belt and fuel filter were all replaced within the last two years 20k miles.
When the fuel tank is at 1/4, the car will often "stumble", idle drops and cuts-out at stop lights. No drivability problems when the tank is full. This only happens after reaching below 1/4 tank.
Is this a sign that the fuel pump is on its way out? I've read that this is rare in a Honda....
Is there a way for a tech to diagnose a dying fuel pump? Just want some educated advice before taking the car in to the tech.
Thanks
Old Jul 11, 2010 | 04:11 PM
skracer13's Avatar
Default Re: 94 Accord - Fuel pump?
if you have access to an oscillascope,(snap on works good) then you can use it to see if it is indeed the fuel pump acting up or another culprit. Compare the siganl waves to when the car is acting up. Also check fuel pressure when below 1/4 tank, make sure within specs.
Old Jul 13, 2010 | 06:49 PM
sobey's Avatar
Thanks skracer13. Appreciate the prompt reply. I'll get the tech to check the fuel pressure when below 1/4 tank. I ran out of gas last summer, and noticed this happening shortly after, so I suspect fuel pump.
Old Jul 13, 2010 | 07:49 PM
phootbag's Avatar
The fuel pump body or pickup hose could have a crack in it causing air to be sucked in when fuel level is low.
Old Jul 15, 2010 | 07:20 PM
sobey's Avatar
Thanks Phootbag.
Fuel pump body and pickup hose are both inside the tank right. Is this a common problem you have seen?
Old Jul 15, 2010 | 08:55 PM
Blackczar22's Avatar
Originally Posted by sobey
Thanks Phootbag.
I dont think its a common problem. Usually its the fuel pump that goes bad not the hoses.
Old Jul 15, 2010 | 09:03 PM
Duane_in_Japan's Avatar
The oscilloscope is my choice as mentioned above, ask your tech if they have an AMP Clamp, do an AMP ramp and evaluate it on the scope, a tech with experience will know what to look for, just look at it after you are having problems.
Not exactly but you can compare wave patterns to another DC motor on your car or the alternator just so you can get a look at what should be going on there, nice even humps. The amount of amps being drawn will require even more experience and a library of wave patterns to make an informed decision on the amount of draw.
Old Jul 15, 2010 | 10:39 PM
phootbag's Avatar
Thanks Phootbag.
I've seen it once. I would call it very uncommon. However, the fact that you pointed out the symptom going away when the tank is above 1/4 tank leads me to suspect this as a possibility.
Old Jul 17, 2010 | 10:50 PM
I am with phootbag on that too, also when the fuel gets low and the fuel pump is not completely immersed in fuel, it tends to heat up and create electrical issues too.
DirtAccord
Sep 20, 2017 08:17 PM
podom
Mar 17, 2016 06:46 PM
GK2
Oct 23, 2013 05:36 AM
94accord89B
Jun 16, 2012 06:27 PM
canospeed200
May 18, 2011 06:05 AM
