92-95 Fully Built Turboed EG Part out
- Parts located in Baton rouge, Louisiana -
- Pay pal +3% will be required on payments -
- Price does not include shipping -
Contact information - Dereks.dunbar@gmail.com
225-505-7729
All items will be shipped via FedEx and insured for the full amount of item.
This is a car we bought to do a shop project on, this car had less then 2k miles on the entire build. We are doing a all motor setup, and parting out the turbo setup. This was a 92 Civic SI - the motor was a d16z6, Everything is for a d series or civic, unless otherwise noted.
Everything was spec and checked as well as cleaned and is ready for shipping
Everything is obo, unless listed otherwise.
NO TRADES
Complete AC line setup for under the hood of a 92-95 civic, minus dryer - 40.00+ Shipping, excellect condition
AC / PS brackets - 25.00 a piece + shipping
NEW AEM TruTime cam gear, new version not old 3 bolt & Crower stage 2 Cam
Looking to sell as a dual product, if you wish i can part each. Price for both is 350.00 + Shipping.
Eagle H-Beam rods , almost perfect.. not a scratch on them..will not include pistons, yes, they do have the ARP/GE Rod bolts incase you were wondering
300.00 + shipping.
ARP D series vtec Headstuds used one time, as you can tell they weren't used for long, they still have the assemble lube on the bottom.
80.00+shipping
92-95 civic cruise control unit, full.
35.00 + shipping
D series vtec dizzy brand new (obdI)
120.00 + shipping
D series vtec oil pump, could use a outside cleaning, gears are almost perfect.
50.00 +Shipping.
D series starter
45.00 + Shipping
D16 tensioner mileage is unknown.
25.00+Shipping
Complete 92-95 power steering setup w/ lines. If need be i can part out.
Complete setup 125.00 - pump 45.00 will not include reservoir.
Fully built d16z6 head
Crower valve springs
Crower titanium retainers
Crower Valves,
KMS Bronze valve guides
KMS valve seals
Could use a hottank for cleaning, almost perfect condition, intake valves are CLEAN and head is well within spec.
Looking for 450.00 + shipping for the head, Will not part out.. this price is obo , i'll work with you on this ..but i'm pretty firm on it.
1000CC injector clinic injectors
pretty much brand new, obdI plug and play
250.00+ shipping.
D16z6 manifold and TB - Complete with all sensors and everything ready to bolt up
80.00 + shipping.
d16 vtec water log and themostat
Will part
full setup - 50.00 + shipping.
Stage 5 comp clutch - with 4 puck unsprung disk - 2k miles, disc has a ton of meat left on it and its a grip clutch
225.00 + shipping
d16z6 block - Bored .020 over w/ Golden Eagle block guard. So fresh you still see the hatch marks on it, no piston expansion either, walls are clean. Comes with mains and all bolts. The block is notched a bit to accept a long rod combo if you wish to do that type of setup, will not effect anything if you choose to use stock rod length setup.
250.00 + shipping
Disreguard the head shots in there...lol
Tial 38mm wastegate w/ 10psi spring
150.00 + shipping
D16 tranny, i believe its an SI, its a p20
No grinds as far as i know, change tranny oil and be on your way
200.00+ shipping
Dseries vtec valvecover
50.00+shipping
D series vtec waterpump - great condition
35.00 + shipping
Complete 92-95 civic piping for a Turbo kit w/ turbo and manifold and oil feed line, as well as tapped d series oil pan for a turbo setup
Turbo is a t3/t4 td04
Log manifold
Turbo has minor, MINOR shaft play, doesn't burn oil however.
will part each part if need be, will not separate piping however. Will part turbo and manifold.
We also have misc interior pieces and what not for sale on a EG hatch. If you think you might need or want something, ask and i may have it.
225-505-7729
NO TRADES
300.00 + shipping.
80.00+shipping
35.00 + shipping
120.00 + shipping
50.00 +Shipping.
D series starter
45.00 + Shipping
25.00+Shipping
Crower Valves,
KMS valve seals
250.00+ shipping.
80.00 + shipping.
Will part
225.00 + shipping
250.00 + shipping
150.00 + shipping
200.00+ shipping
50.00+shipping
35.00 + shipping
Log manifold
not looking to do anything that requires cash on my end... if someone wants to trade pieces thats fine.. If you'd like to trade the wastegate for the h22 w/o the cams thats fine, we're not using stock cams on our build anyway, Thx for the offer however.
