Lots of Good Sh@t!!!! B-series
I have lots of stuff for sale and would prefer pickup but am also willing to ship all is located in Baton Rouge,La @ 70816
1.) Barely used -ACT Prolite flywheel 8.8lbs. #ACT-600105
FITS THE FOLLOWING VEHICLES
1990 Acura Integra B-Series, Cable
1991 Acura Integra B-Series, Cable
1992 Acura Integra B-Series, Cable
1993 Acura Integra B-Series, Cable
1994 Acura Integra B--Series, GSR / Type R
1995 Acura Integra B--Series, GSR / Type R
1996 Acura Integra B--Series, GSR / Type R
1997 Acura Integra B--Series, GSR / Type R
1998 Acura Integra B--Series, GSR / Type R
1999 Acura Integra B--Series, GSR / Type R
2000 Acura Integra B--Series, GSR / Type R
2001 Acura Integra B--Series, GSR / Type R
1994 Acura Integra B-Series, Hydraulic - LS, RS
1995 Acura Integra B-Series, Hydraulic - LS, RS
1996 Acura Integra B-Series, Hydraulic - LS, RS
1997 Acura Integra B-Series, Hydraulic - LS, RS
1998 Acura Integra B-Series, Hydraulic - LS, RS
1999 Acura Integra B-Series, Hydraulic - LS, RS
2000 Acura Integra B-Series, Hydraulic - LS, RS
2001 Acura Integra B-Series, Hydraulic - LS, RS
1999 Honda Civic Si VTEC, DOHC, B Series, 220mm
2000 Honda Civic Si VTEC, DOHC, B Series, 220mm
1998 Honda CR-V Standard Engine
1999 Honda CR-V Standard Engine
2000 Honda CR-V Standard Engine
2001 Honda CR-V Standard Engine
1994 Honda Del Sol VTEC, DOHC, B Series, 220mm
1995 Honda Del Sol VTEC, DOHC, B Series, 220mm
1996 Honda Del Sol VTEC, DOHC, B Series, 220mm
1997 Honda Del Sol VTEC, DOHC, B Series, 220mm
$150
2.) Freshly knife edged B16 Crank
$100
3.) Manual P28 ecu socketed and chipped w/ OBDI-OBDII harness
$280
4.) B16a complete shortblock w/ less then 55k
$300obo
5.) 2nd B16 complete shortblock also w/ less then 55k
$300obo
6.) Used Skunk2 Racing Camber Kit for 96-00 Civic
These need balljoints which just screw on/off very easily I have 1 new balljoint that will be included in the sale.
$125
7.) B16 Intake manifold w/ TB
$75
8.) Manual B20 engine harness ( un-cut )
$100
9.) B16 Exhaust Manifold & A pipe section
$40ea
10.) B-series Engine mount brackets (driver's side upper & rear T-brace)
$30 for driver's side, $50 for the rear
11.) B16a2 Oil pan
$40
12.) B16a2 Oil pan tapped for turbo oil return
$65
13.) B16 Distributor w/ Cap OBD0 I believe as it was from a CRX
$30
14.) Adjustable steering Column form a 95' GSR (great upgrade especially for EG's)
$30
15.) CRX B-series Motor Mounts (only used for mock up )
$45
16.) Drag gen. 3 Turbo Kit left overs.
The turbo has shaft play and will need to be rebuilt, wastegate has a 7lb spring currently, all IC pipes are there for a 96-00 Civic not sure what else it will work with, Drag log style exhaust/turbo manifold, and downpipe. I will seperate this stuff or sell it all together
for the right price feel free to make offers on all of it and if I can't just get rid of it all at one shot then I will happy to seperate for you guys....
$150
$100
$280
$300obo
$300obo
$125
$75
$100
$40ea
11.) B16a2 Oil pan
$40
$65
$30
$30
$45
ohboy95c
Sep 11, 2008 07:28 AM
