Spindle hitting coil spring- Help!!!
The other night i was on my way home when a lady came into my lane. I steered to the left to avoid getting hit and caught a storm drain. The impact broke my wheel. Ive got new wheels on the car now and I had the alignment fixed. When I got it aligned they said that nothing seemed to be bent. So I drive home today and every time I hit a bump I hear noise coming from the left front. I jack the car up and take the wheel off and can see where the front spindle is hitting the coil springs.....which is the cause of the noise. Any ideas of where to start???
the digital camera is broken.... im pretty low in the front and have not adjusted the camber. The camber is at 4.5* on both sides. Only the driver side hits. If i buy a camber kit and pull the camber out, then it should bring the spindle away from the coil right....?
Stein
Aug 16, 2004 07:48 PM
