LS V Short Block
****WILL TRADE OR DO PARTIAL TRADES IF YOU HAVE A GOLD BEAKS REAR LOWER TIE BAR FOR EG'S or a Rear Sway Bar non OEM (must be in good condition no scratches)
Will post pics later or PM for pics
Located MN/WI boarder
B18a Short block - Built for LS-V - Make an offer (short block only)
Complete from deck to oil pan (no flywheel or clutch, have bolts though)
Parts/mods Added:
Honed/cleaned
JDM P30 b16 pistons
NPR std size Piston rings (new)
ARP rod bolts (new)
ACL Bearings (rod, main, and thrust) (new)
OEM vtec oil pump (new)
OEM 22t vtec water pump (used)
GSR Timing Belt (new o'reily's brand)
Stant Thermostat
Oil Pan gasket (new o'reily's brand)
OBD2 to OBD1 ECU jumper Harness from 1998 civic ex - $40
unknown brand
OEM head bolts for d18y8 may fit others (x10) - Paid 18.40 will take $15
OEM valve seals intake and exhaust (8 for each side) -Paid 17.28 will take $15
OEM d16y8 head gasket may fit others - Paid $24.03 will take $20
Also have those cheap ebay gasket kits for a D15. Onlything missing is the exhaust manifold gasket - dont need no more $20 I believe its for the comple kit for the head
5" tach with shift light - $50
Speedo healer *NEW(works to correct s2000 retro fit or correct speedo for bikes with sprocket changes) - $100
Parts/mods Added:
Honed/cleaned
JDM P30 b16 pistons
ARP rod bolts (new)
Stant Thermostat
unknown brand
