EG Half size radiator and FAL Fan
Old Jul 10, 2010 | 08:56 PM
donaldmejr's Avatar
Default EG Half size radiator and FAL Fan
Guys I need some help wiring up my EG FAL fan. The fan came with a red (+power) and black (-Ground) wire. But my 88 HF crx comes with black/yellow and Blue. My question is easy...what wire goes where? I would like the fan to function like OEM and not just always on.
Old Jul 10, 2010 | 09:17 PM
LamEF's Avatar
Default Re: EG Half size radiator and FAL Fan
got a multimeter? that'd be the easiest thing to do. just test the wires with a cold engine, and test them with a hot engine, not to complicated.
I would think they would be like this
black - ground
yellow - constant or ignition
blue - water temp. probably hot only when the engine reaches operating temp.
Ya might need a relay?
Old Jul 10, 2010 | 09:24 PM
donaldmejr's Avatar
Well I found this...and what it seems like is Blk/Yel is constant or ignition and Blue is ground but only when the rad fan relay coil is pulled in by the coolant temp switch. Can someone comfirm that what Im thinking is correct?
Old Jul 10, 2010 | 09:38 PM
LamEF's Avatar
ohhh, wow, I read ur post wrong...fail.
anyways, yeah thats correct, the blue wire goes on the black wire. its is grounded through the fan relay once the car gets hot enough.
axelintegra
Aug 30, 2009 05:47 AM
akouznet
May 23, 2009 08:33 PM
socialistic
Sep 10, 2008 03:45 AM
89dxhunchback
Nov 27, 2003 04:10 AM
