WTB: 96-01 OEM GSR Catalytic Converter ASAP!!!!!
Hey guys, anyone that has one they want to sell me, I need one ASAP. My tags are almost up. The cat has to have the both ports for the primary and secondary o2 sensor ON THE CAT. Let me know.
I actually just recently bought the magnaflow universal CA complaint cat converter, part number 46034 with a legal CARB EO number on the cat, guess what, BAR said NO and that the CARB EO number has to be a mistake haha. Thats why I'm looking for another one. The catalytic converter has to have two ports for the primary and secondary o2 sensor. If you have any cats, universal or oem fit, with 2 holes for the primary and secondary o2 sensor on the cat, ill take it. Although personally I have searched high and low and no aftermarket company seems to have two openings for both o2 sesnors on the cat -_-. LET ME KNOW if you have something cuz I'm desperate, my tags are almost up and I need to smog!! California legal cat only! Thanks.
here is the paperwork for you.
http://images.magnaflow.com/02catalo...nia_in_pdf.pdf
http://www.magnaflow.com/02catalytic...niversal=46034
also take CARB EO # off the cat and plug it in on this site....
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
print the results as well. Shows # 46034 is in fact for the Integra and for 1996-2001 years in CALIFORNIA!
I printed out all those papers from the aftermarket EO database site and they still told me its not legal. They called the California Air and Resource Board and the board is saying that it must be a mistake because it doesn't have provisions for the primary 02 on the cat... -______________________________-
They are basically saying even though there is the CARB number on there, you can't use that CAT because according to our database, it doesn't have the correct provisions for the primary o2 sensor. They said don' come back til u have one that does -_______-. EVEN WITH ALL THOSE PAPERS!! THey just shoved it back into my face.
I have a super awesome OBD2 cat that will work for you. I recently found it wasnt OEM, but it passed emissions with flying colors
PM and make me an offer, will send pictures
My cat has an O2 sensor spot behind the cat like stock
Unfortunately, unless it has a spot for the o2 sensor in front AS WELL as in the back, its not the right one. Plus I see that you are in WI, 49 state aftermarket cats are not the same as Cali legal cats. Thanks anyway though.
no. It suppose to have two total, one in the front of the cat and one on the back of the cat, but both provisions for the o2 sensors are ON the cat. Post a pic and let me see what you got.
Im gvuessing your manifold/header doesnt have an O2 spot on it?
My OBD2 cat has only the secondary after the cat, since 49state have the o2 primary on the front of the motor
difference is minimal, might need a wire extenstion
Easier to just get a double O2 cat i guess..
oh well
http://i244.photobucket.com/albums/g...Sales/cat1.jpg
http://i244.photobucket.com/albums/g...Sales/cat3.jpg
Yeaaa, the GSR cali obd2 cat has both sensors ON the cat, and none on the exhaust manifold, it's a little different. Thanks for the help anyway though man, much appreciated.
I would go to a different BAR station, and what OBD2 are you talking about A or B, my 99 LS has primary port on the end of the exhaust manifold, and 2nd port on the end of the cat...Which should be the same for GSR, and type R OBD2A.
i just had a bard test yesterday.i have a ek swapped 98 gsr engine so i put a magnaflow catalytic #46043 and they said its a acura integra catalytic but its not for GSR!!! and it only have one sensor i need to look for a 98 gsr catalytic with two sensor to connect.i went to acura and check how much for a catalytic for a 98 acura integra GSR!! its $800 dollars whoa now its pain in the *** where can i find a cheap one and bar can recognize the catalytic if its legal
akandok
Sep 25, 2008 01:56 PM
