89 civic si, stalls out and wont start for a while??????
Old Sep 15, 2002 | 11:13 AM
kizner's Avatar
Default 89 civic si, stalls out and wont start for a while??????
When i start the car sometimes it will stall out and not start for anywhere from 5 minutes to 30 minutes. I tried switching ignitors, and coil. still no luck, also tried fuel injector resistor box, no luck. any ideas are appreciated
Old Sep 15, 2002 | 11:26 AM
RuthlessEF-9's Avatar
Default Re: 89 civic si, stalls out and wont start for a while?????? (kizner)
check your vaccum lines
Old Sep 15, 2002 | 03:56 PM
Jaker's Avatar
PGMFI relay, also know as main relay.
[Modified by Jaker, 4:57 PM 9/15/2002]
Old Sep 15, 2002 | 03:59 PM
chirp2hrd's Avatar
Default Re: 89 civic si, stalls out and wont start for a while?????? (Jaker)
yes i would also say main relay, do you hear your fuel pump when u turn the key and prime the car?? if you dont hear the fuel pump then its most likely the main relay or check the distributor but it might be the vaccum lines good luck
Brand
21
Sep 8, 2022 09:39 AM
91rexhf
Dec 30, 2008 11:35 AM
Si-Samuri
29
Jun 19, 2008 05:48 PM
dot.org
Oct 6, 2007 08:46 AM
AgentJam
Aug 15, 2004 03:07 PM
