Suspension & Brakes Theory, alignment, spring rates....
Alignment issues! Please help. Toe can't be adjusted any more..
Old Jul 10, 2010 | 11:46 AM
cBrown05's Avatar
Default Alignment issues! Please help. Toe can't be adjusted any more..
A little history, the car is a 95 Integra GSR. When I bought it, it had ITR 5-lugs. I didn't want the extra attention so I traded a guy (we made a deal of course) for a 4-lug setup he had laying around. He did all the work for me as I've never swapped suspension before. Nice guy. The front end seems to be fine. However, the rear is way outta wack. The heat shields on the rear are Civic Si blue, which leads me to believe that some or all of the rear is from an Si. He said it'd be fine, the Si and Integra have the same suspension. So, I said ok, I'll just go get an alignment, it's fine. So, I take the car to the shop today to get the alignment done, and the mechanic tells me that the driver-side rear toe is out by 1 inch. And he can't adjust it anymore. He said they make an adjustable aftermarket part that can be used between the trailing arm and the frame? I'm not really sure what he's talking about. Can someone please enlighten me? Can I still use these parts?
Oh, also, there is no where to plug in my ABS sensors in the rear.. Do I need to replace the brake assemblies with Integra ones? What parts would I need?
Old Jul 10, 2010 | 11:53 AM
Turbogixxer's Avatar
Default Re: Alignment issues! Please help. Toe can't be adjusted any more..
It is a hardrace toe adjustment.
Old Jul 10, 2010 | 12:44 PM
cBrown05's Avatar
Hmm.. That one is $140.. But I did google "integra rear toe kit" and found one from Wicked Tuning with pretty good reviews for $50.. Which is better, but I'd still like to know why I can't use what's already on my car and not waste $50 on a useless part.. =/ Is this a common issue? Is there anything else I can try? Thanks for the reply.
Old Jul 10, 2010 | 01:21 PM
Tyson's Avatar
an aftermarket toe arm would be a bandaid solution to the problem.
you either have the wrong components on the car, or a bent trailing arm. fixing and replacing the bad part would be the right solution, not trying to get around the problem with a longer arm.
figure out what the problem is. i suspect a bent trailing arm. or possibly the wrong compensator arm.
Old Jul 10, 2010 | 01:53 PM
kristo's Avatar
Loved
Compensator arms are indeed different (part#) between EK and EG/ITR.
Toe out by 1inch is huge
Old Jul 10, 2010 | 02:16 PM
pkdog167's Avatar
It could be a compensator arms or the worse a bend trailing arm.
Old Jul 11, 2010 | 01:08 PM
cBrown05's Avatar
Thanks for all the replies guys. I went ahead and ordered these:
http://cgi.ebay.com/ebaymotors/WICKE...Q5fAccessories
Are those the same thing as a "compensator arm"? Hopefully that'll fix my problem.. And can you lend any advice about the ABS sensor?
Thanks.
Old Jul 11, 2010 | 01:49 PM
Jenkinsal2's Avatar
The toe link and the compensator arm are the same part essentially.
Old Jul 13, 2010 | 02:06 PM
TunerN00b's Avatar
You ignored the only good advice in this thread.
Old Jul 14, 2010 | 06:59 AM
dpetro1's Avatar
Thanks.
a compensator arm is an oem piece. those aftermarket pieces are not the solution to your problem.
#14 - compensator arm
#20/21 - trailing arms
Old Jul 15, 2010 | 04:51 PM
cBrown05's Avatar
Well, I needed an easy and quick solution right away. I'm confident I can change out the compensator arm. And not so confident with the trailing arm.. How much is a new trailing arm? You don't think that if it's bent just a little, that when it's aligned everything should be fine?
Old Jul 15, 2010 | 07:19 PM
crazyheadrush's Avatar
Do u have pictures? If its got +/-1 toe than ur trailing arm is gonna be bent. Are u sre he didnt mean +/-1 camber?
Old Jul 15, 2010 | 07:51 PM
98civdx's Avatar
Master Detailer
New trailing arms from honda are 300+
Old Jul 16, 2010 | 08:20 AM
cBrown05's Avatar
Hmm.. Maybe I'll check out the junkyard.. I just want this fixed. It's definitely the toe, not the camber.. Then once that's fixed, I need to buy the correct brake assembly for the abs sensor. This sucks. Thanks for the help. </thread>
cBrown05
Jul 11, 2010 09:05 PM
JasonST
Suspension & Brakes
Feb 3, 2008 04:24 PM
ken-shin
Suspension & Brakes
Apr 7, 2006 08:31 AM
Silroan
May 23, 2004 06:13 PM
blah13
Jul 28, 2003 08:47 PM
