No voltage at radiator fan
Old Jul 10, 2010 | 11:41 AM
Schultzie's Avatar
Default No voltage at radiator fan
So my rad fan is not turning on. I broke out a multimeter and tested several place for voltage. At the battery is 14volts, at the fan relay is 14 volts, at fan switch is 14 volts and at the fan connecter there is 0 volts. the wires from the fuse box to the fan are all in tack. Anyone have any idea whats up? I know you need 12 volts for the fan to operate. I'm just wandering why it has 0 volts at the fan.
Old Jul 10, 2010 | 11:44 AM
erichackett's Avatar
Default Re: No voltage at radiator fan
check fuses, check your ground. i had mine go out on my (ground cable) and for the life of me couldnt figure out why the fan wasnt working... also use a test light. it will show if your wires are actually carrying current rather than just showing voltage.
Old Jul 10, 2010 | 11:51 AM
Schultzie's Avatar
fuses are all good. My ground cable was replaced a few months ago so it's shiny and new. I don't have a test light. Can you think of anything else bro?
Old Jul 10, 2010 | 11:53 AM
where the cable from your wire harness hooks up to the radiator fan is that at 14 volts? if not i would follow that wire all the way back untill you find a voltage.
Old Jul 10, 2010 | 11:54 AM
and a test light is something you should get.. theyre like under 10 bucks..
Former User's Avatar
Unplug the 2P connector for the fan switch on the thermostat housing. Install a jumper wire to short the two terminals in the plug and then turn the key to ON(II). Does the fan now run continuously?
Old Jul 10, 2010 | 12:22 PM
Schultzie's Avatar
ron with the jumper wire I have no movement at all from the radiator
Old Jul 10, 2010 | 12:26 PM
With the jumper wire installed and the key in ON(II), do you now measure battery voltage at the fan connector? If so, the fan is probably bad.
Old Jul 10, 2010 | 12:32 PM
Schultzie's Avatar
ron I am sorry. I spoke too soon. I re read your post and googled jumper wire. I can across a diagram and saw that you wanted a jumper wire just on the thermo plug. I was trying to run a wire from thermo plug directly to fan. I'm an idiot. I did the jumper wire how you said and the fan is spinning. I guess this means the fan switch is bad.
Old Jul 10, 2010 | 01:09 PM
Before you replace the switch, bleed the cooling system. Air trapped in the system could also prevent the switch from activating. If bleeding does not help, replace the switch.
Old Jul 10, 2010 | 02:40 PM
Schultzie's Avatar
Thank you for all the help Ron. It was the switch! Got the coolant bled and everything is running well after the bleed and new switch
Old Jul 18, 2010 | 06:11 AM
NOTUNINGNONADA's Avatar
how did you bleed it???
j4s0n1337
52
May 13, 2011 09:55 PM
BlackShingo
May 3, 2010 08:51 AM
jdmsir4dr
Feb 21, 2009 09:54 PM
limit
Dec 30, 2008 01:28 PM
Doh!
Jul 3, 2006 09:29 PM
